I see a lot of guides from changing PAL to NTSC, but none about just changing the fps. I have a movie w/ 20 fps and i would like to change it to any NTSC frame rate. Are there any guides that aren't on this site? Or can somebody just tell me a way to do it and still keep good quality? Thanks a lot!
VirtualdubMod or TMPGEnc will do that among many others. As far as keeping the quality, you'll just have to try it. Sound sync may be a problem.
If this was a DVD rip that you processed through DVD2AVI then if you have FORCE FILM checkmarked on a PAL source (25fps source) you end up with 20fps
That's the only way I know to accidently make a 20fps video file.
- John "FulciLives" Coleman
P.S.
FORCE FILM option in DVD2AVI can only be used on certain NTSC DVD sources and not for PAL at all!"The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference between 23.976 fps and 23.98 fps ???
By wasimismail in forum Authoring (VCD/SVCD)Replies: 5Last Post: 27th May 2008, 01:42 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:29
