I want to capture MPEG2 at 720 x 480, and get the highest quality possible while still being able to fit 2 1/2 hours on a DVD. Any suggestions as to what bitrate I should be capturing at? Can I capture at 3.5 Mbps like I do with 352 X 480, or do I have to capture at a higher bitrate for the bigger resolution? Thanks.
From my calculations based on past experiences, in order to get 150 minutes of 720x480 mpeg2 onto a standard DVD, you you need encode at 3.990 Mbps or less. I have been using the formula 598533/bitrate = minutes on DVD.
I hope this works for you. -
This method has been quite succesful for me when capturing vhs.
Capture at 720X480, 6Mbs, 48k audio
Author the mpg to dvd and add chapters, and menu's if you wish.
Use dvdshrink with deep analasys to fit to dvdr
Done.
It's been my experience that a capture using the above method
gives me a crisper, more dvd-like, look than a 320X480 low-bit capture.
Burn to an rw and see if it works for you.
Happy capping
kiki
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03 -
Bitrate question compiling a DVD
By dvdnewb2 in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 09:31
