I'm trying to check if I have DMA enabled, This is what I do, right click my computer/properties/hardware/device manager/right click hard drive/can't find it. Am I missing something? Any advice welcome
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
I must be getting stupid in my old age. I finally found it in IDE controllers. Sorry.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
You have to dig around sometimes. I tried NeroInfoTool_207 a few days ago and it will tell you that and a lot more useful information about your drives. Handy little program.
Just going off topic for a second, why is my avatar not moving on my wi2k computer, but moving on my winxp?
Are you using same browsers/browser settings on both?
If you have a firewall check the settings under ad blocking and make sure animations are not selected.Originally Posted by tweedledee
Thanks Craig, That was the reason. My Zone Alarm was set to block animations.
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 10:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 14:45 -
Weird Doings in PIO - DMA-ville
By Seeker47 in forum ComputerReplies: 13Last Post: 28th Nov 2008, 13:15 -
DMA PIO Reg Prob Key Deleted returns after reboot
By tonib95 in forum ComputerReplies: 14Last Post: 4th Feb 2008, 10:23 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 22:35
