Hello all,
I have followed several converting guides, and I am following each one exactly.
My problem is this. When I load up my .avi file in Gspot, the codes that the files uses are DIVX4 and MPEG 1 - Layer 3. Ok, fine. Now, I use Vdub Freeze and Vdub to remove bad frames and pull of the audio file. Fine. No problem. I then use TMPGenc Plus to convert to SVCD. Conversion goes through no problem. Now, when I open up the file in Widows Media Player, I get a "Class Factory" error. I clicked on the ever helpful "more help" button for Microsoft and of course, came up with nothing. So, I open up the mpeg file in Gspot and tells me that there are no codes being used.
Can someone give me some advice here?
Thanks,
LG
have you installed a mpeg2 codec or a dvd player like windvd or powerdvd? svcd is mpeg2.
You've made an mpeg2 which media player cannot handle because you need an mpeg2 codec. Install PowerDVD (even the trial version) which will give you the codec.Originally Posted by Lucifers_Ghost
Gspot does not test mpegs, try avicodec.
Beat me to it.
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 10:14 -
MKV to IPOD conversion error
By ganjasmoker in forum Video ConversionReplies: 6Last Post: 7th Nov 2009, 23:20 -
Error with FAVC Video Conversion
By IllusionOfLife in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2009, 17:38 -
Auto GK conversion error:
By sibaroochi in forum Video ConversionReplies: 1Last Post: 28th Jan 2009, 05:26 -
Divx conversion error with VirtualDubMod
By newnews in forum Video ConversionReplies: 4Last Post: 8th Feb 2008, 15:15
