Hi,
I'm experiencing a strange problem trying to convert some mpeg files to dvd using ffmpegX. What I want is to simply encode the audio into mp2 224/48000 (leaving the video untouched). However, I keep getting incomplete mp2 files that only contain ten minutes, fifteen minutes of audio. Synching and sound is perfect after I've authored the files in sizzle.
I get different terminal error message; at times it's a 'segmentation fault' sometimes it's a 'bus error' and what's really strange is that I get different error messages when I try and encode the same file! I've tried just demuxing the audio/video and gotten perfect results sometimes - and sometimes not - but I want to resample the audio to 224/48000 to be able to play it on a standalone DVD player.
Any advice/help greatly appreciated!
MJ
how is it you set this up?
my tutorial on my website gives you setp by step how to for ffmpegx
check it out
its in SVCD to DVD section
AnonymousGuest
Actually, I've been following your instructions to the letter! That's how I first started using ffmpegX. I trotted off to your guide and did exactly as you instructed
which is why the thing is so baffling. Do you want me to send you the entire terminal log? I can do so privately since I don't really want to take up space with it here. I should add I'm running Panther on a G4 500/AGP with 256MB memory.
MJ
Problems with extracting srt subtitles from a DVD with CCExtractor
By stibi in forum SubtitleReplies: 20Last Post: 13th Jul 2011, 18:29 -
Problems with extracting DTS from MKV
By Raf_a in forum Video ConversionReplies: 2Last Post: 5th Jul 2011, 01:44 -
Extracting VOBs To M2V gives me alot of problems.
By Discov3r3d in forum DVD RippingReplies: 5Last Post: 18th Aug 2009, 15:41 -
Extracting audio from .ts
By leopardx in forum Video ConversionReplies: 2Last Post: 23rd Apr 2009, 16:22 -
Extracting LPCM audio from Blu-Ray (problems)
By delirial in forum Blu-ray RippingReplies: 4Last Post: 22nd Feb 2009, 04:04
