How can I backup a DVD onto a blank DVD with a DVD Drive (Toshiba SD-R1312) and a DVD Writer (Plextor PX-708A)?
Results 1 to 30 of 31
Check this out.Look under dvd rip.I use Anydvd and clonedvd the most.
If i have to compress too much,i use intervideo dvd to split the movie to 2 dvdr's.Not one coaster with either method.
https://www.videohelp.com/guides.php?howtoselect=6;30bmiller,ont.canada -
I tried to make a backup with DVD Shrink, and I got a Copy Protection Error. I was trying to back up Head of State, what is the problem?
I have learned that the experienced people on this forum don't help too much with simple newbie questions so I'll add.
You first have to decrypt the dvd to the hard drive with DVD Decrypter 3.1.9.0, then you use DVD Shrink to compress it. Then burn the DVD using Nero 5.5 or 6 or a burning program of your own. There are several key steps in between but too much to list here.
There are many how-to's on this website. Take some good time and research. It taught me all the basics!
DVD X Copy is not worth the money. The above programs are freeware and are more flexible in what they do. -
I downloaded AnyDVD and then it took off that protection error. I used DVD Shrink to burn it and it encrypted it, now its burning and its at 17%. Is the DVD going to turn out bad?
Damn! I got this error right after I posted. Here is the log of what happened:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/25/2002 10:34:54 AM
Nero API version: 5.5.10.5
Using interface version: 6.0.0.0
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <PLEXTOR DVDR PX-708A> Version: 1.04 - HA 1 TA 1 - 5.5.10.5
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD800AB-22CBA1 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TOSHIBA DVD-ROM SD-R1312 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : PLEXTOR DVDR PX-708A atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 70254592 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 479MB (490992kB)
Free physical memory: 179MB (184084kB)
Memory in use : 62 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
24.1.2004
NeroAPI
11:55:57 PM #1 Phase 111 File APIProgress.cpp, Line 224
DVD-Video files sorted
11:55:57 PM #2 Text 0 File Reader.cpp, Line 115
Reader running
11:55:57 PM #3 Text 0 File Writer.cpp, Line 123
Writer PLEXTOR DVDR PX-708A running
11:55:57 PM #4 ISO9660GEN -11 File geniso.cpp, Line 4546
First writeable address = 0 (0x00000000)
11:55:57 PM #5 ISO9660GEN -11 File geniso.cpp, Line 4546
11:55:57 PM #6 Text 0 File Burncd.cpp, Line 3798
Turn on Disc-At-Once, using DVD media
11:55:57 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 670
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2286160 (2286160) = #2286160/508:2.10
relocatable, CD pos for caching/writing not required/required, no patch infos
11:55:57 PM #8 Text 0 File DlgWaitCD.cpp, Line 203
Last possible write address on media: 2295103 (510:03.28)
Last address to be written: 2286159 (508:04.09)
11:55:57 PM #9 Text 0 File DlgWaitCD.cpp, Line 208
Write in overburning mode: FALSE
11:55:57 PM #10 Text 0 File DlgWaitCD.cpp, Line 1452
Recorder: PLEXTOR DVDR PX-708A;
CDR code: 00 00 00 00; CD manufacturer unknown
ATIP Data: ?
11:55:57 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 822
Prepare recorder PLEXTOR DVDR PX-708A for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 387395584
11:55:57 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 670
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286160 blocks [PLEXTOR DVDR PX-708A ]
11:55:57 PM #13 Phase 24 File APIProgress.cpp, Line 224
Caching of files started
11:55:57 PM #14 Phase 25 File APIProgress.cpp, Line 224
Caching of files completed
11:55:57 PM #15 Phase 36 File APIProgress.cpp, Line 224
Burn process started at 8x (11,040 KB/s)
11:55:57 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 1963
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
11:55:57 PM #17 SCSI -1066 File Cdrdrv.cpp, Line 1196
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x017F6000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
11:57:56 PM #18 SCSI -1093 File Cdrdrv.cpp, Line 1400
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x01780000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x05 0xAF 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x08 0xAF 0xA0 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
11:57:56 PM #19 DVDR -1093 File Writer.cpp, Line 331
No seek complete
11:57:56 PM #20 Text 0 File ThreadedTransfer.cpp, Line 219
all writers idle, stopping conversion
11:57:56 PM #21 Text 0 File ThreadedTransfer.cpp, Line 213
conversion idle, stopping reader
11:58:03 PM #22 SCSI -1176 File Cdrdrv.cpp, Line 1196
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x03
11:58:03 PM #23 DVDR -1176 File WriterStatus.cpp, Line 163
Session fixation error
11:58:03 PM #24 TRANSFER -24 File WriterStatus.cpp, Line 163
Could not perform end of Disc-At-Once
11:58:03 PM #25 Phase 38 File APIProgress.cpp, Line 224
Burn process failed at 8x (11,040 KB/s)
11:58:03 PM #26 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.1.1.7 , size=24698 bytes, created 6/25/2003 12:18:48 AM
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
What happened? Is this because I didn't Decrypt it? -
It's compressed down to 17%? I've never compressed one that low. I can't imagine that it's going to turn out very sharp. I've compressed down to 50 some percent and it turns out great.
Here's a great link for how to articles:
https://www.videohelp.com/guides.php?howtoselect=6;30 -
I didn't compress it that low, that was just the percent it was burning at.
Oh, ok. I've never used AnyDVD so I'm not real sure. I'm still a newbie of sorts. I've only used DVD Decrypter and DVD Shrink with excellent luck. I did make a few coasters when learning however.....
I just need a quick and easy way to back up a DVD onto a single blank DVD+R.
Quick and easy - DVD X Copy Express. Very easy interface, does everything for you - decrypts, compresses, burns it too. This is what it does:
Burn DVD Movies to DVD-R(W) and DVD +R(W) disks
Copies full multi-channel audio (dolby digital 5.1, dts)
Simple, one-click interface
Copies dvd movie to one blank disk (no need to split)
However it will not:
Copy special features (movie trailers, commentary, etc)
Copy every language available on original dvd movie
Copy episodic DVD movies (sopranos, simpsons, etc)
Specify which special features to keep or remove
Easy-peasy Japaneasy (except it costs money)
It does add a disclaimer to the beginning of the DVD about being a copy and pirating is illegal, etc. (doesn't matter if it's a backup of your own DVD, who cares??)
If you want more than that, you have to work at it and learn the freeware. -
I use any dvd with clone dvd.Decrypts and compresses if necessary at the same time.I used to burn with nero,but i had so many problems with it i switched to record now max.Load the VIDEO_TS folder and burn.Not a coaster yet.I only keep the movie and menus.If i have to compress more than 20%,i'll put it on 2 disks.There isn't much advantage to a dvd player,a widescreen tv,and 480p if the quality of the movie you end up with is no better than a vhs tape anyway.To each his own.
No, they put 100% effort into helping the people that have done some basic research first.Originally Posted by dopp5
Have you any idea how the people who write the comprehensive guides feel?
They write a guide, a guide including pictures, simple instructions etc. only for people to come on and say 'how do I copy a DVD'?
I think a little balance is due here, don't you?
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I completely agree about his original question. I couldn't believe it was actually posted. However I did point out a few times about researching the website. My only problem was that when I started out, I looked thru the forums and guides looking for an answer to a question that I had and couldn't find anything specific on it. THEN, I posted the question and had absolutely no response. That kind of surprised me. That's all I'm saying. Thanks for the response.
(We are all newbies at some point) -
I backed it up with DVD X Copy (I purchased it online last night), and it seems to work in the PC, but I put it in the DVD Player in my Van. It plays the DVD, but its like its fast forwarding. Like still pictures every 4 seconds. What do you think caused this? Is it an incompatibility, or is it because it is -22 Degrees Celcius outside (condensation, something like that). I also don't hear any sound.
I just wish there was a website somewhere someplace that would have info easy at hand so people would not be forced to ask questions like this at a forum. Maybe put the info in simple to understand links to the left of the screen... maybe one day.
copying dvds has became so easy and simple compared to like a year or two ago. so when someone says they don't know how or can't find the answer. there either really dumb or real lazy.
Originally Posted by K(c)offee
Man, I almost fell for this.Surley you should one of these at the end =
Despite my post I don't practice what I preach.Originally Posted by popp5
When I first came (and it was before my username suggests, I lost my original passcode and had to re-register, twice!) I struggled with the guides but then dvd backup was nothing like it is now.
I'll never for get those 16 hours encodes with a Duron 900
If you check sonme of my posts (and not the ones where people piss me off!) I do try to reflect the fact we were all newbies in my answers (although, many, many people will disagree with that!).
The poeple who annoy me most are the ones who should know better, the ones who know it all and look down their noses at you).
Those will be the reason I get baned
Take care,
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by Poke598
Am I getting old are am just I missing al the jokes tonight?
Did you check the compatability of your van's dvd player with DVD+R media? Did you try out the DVD on a regular DVD player on a tv? Keep in mind that DVD-R's are slightly more recognizable on dvd players than DVD+R's.
Will Hay:
Well said. -
I thought poke598's post was a wind-up, no?
The following is for dopp5's benefit, can't do this via PM.
Will Hay
The probable resolution to this issue is to FIRST run the dvd in question with a software dvd player (ex powerdvd) for a few seconds. Then use dvdshrink to shrink it to fit on one dvdr.I tried to make a backup with DVD Shrink, and I got a Copy Protection Error. I was trying to back up Head of State, what is the problem?
As an "old timer" on the board, my nickels worth of free advice is to do a search before posting. Many if not all of your questions have been answered before, this question IS a VERY basic question. Further, a large number of the guides on this site have (with pictures) the resolution to your problem.
As far as the other parts of the thread, personally I am SHOCKED that this thread did not turn into a flame thread. Before, a question like this would have brought everyone out in droves to PERSONALLY ridicule the poster. Apparently, those folks have moved on (or decided to let this one go).
Anyway, some advice would be to do some searches and look at some guides before posting. Welcome to dvdrhelp.com.
[/code] -
When you arrive at this site for the first time, you are overwhelmed with the amount of information given for so many slightly different topics/ methods. Just look at the link given for the guides. Where do you start?
It is easier just to arrive at the forum and get some direct answers for direct questions.
Dvd Backup
By DIKYDO in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 09:30 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 01:50 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Help with DVD Backup
By zeroplace in forum DVD RippingReplies: 3Last Post: 23rd Jun 2008, 10:48 -
DVD Backup
By romanstopme in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 09:38
