  1. I'm tryin to burn 3 episodes on a vcd with a navagational menu but I have no clue how. I read all the guides and searched the forums but with no luck. What I'm trying to do is that after converting my avi files to mpegs I like would to create screenshots of of each eps on a vcd menu. So far for each episode it starts out with the same opening sceneshot. Is there a way that will enable me to pick a still from each video file and use it as a menu? ex. chapter 1,2,3 etc..
  2. yes it is very possible. i use tmpgenc to capture the picture i want to use for each scene and then use vcdeasy to link them all together so that when pres #4, for example, on my remote, it will go to chapter 4.
  3. thanks for the tip, would you happen to have a guide for what you just said? I'm still a newbie to this whole video encoding deal. Just recently downloaded tmpgenc and thats what I used to encode all my avi files. I search the tmpgenc help files however found nothing on capturing the video, and I also just downloaded vcdeasy today. Could anyone break it down in 1,2,3 steps? Ill be grateful 4 any help you guys can give me.
  4. i'm sorry. try this link here.. http://users3.ev1.net/~CavemanLawyer/
    this is the guide i used when i first started making my chapters and scene selections. hope this helps.
