I have two films of 1 hr 16 mins and the other of 1 hr 6 mins on a DVD-r. I'm looking to rip them both from the original DVD edit out any commercials and then re-combine the two films into one long film then burn it back onto a DVD. The question is how do I do this and which tools are the best to use? Hopefully I'm looking to use TMPGenc to re-encode the files into mpeg2 for the DVD authoring process but I dont know how to extract the two films and then splice them together.
Thanks in advance
Liam
I found a thread which addresses your question. It involves ripping the DVD's, re-authoring and then compressing to fit a DVD-R. Look here, and ignore some of it but there's a really good post which tells you just how to do it.
Capturing films from camcorder and then burning to DVD
By peterlouisbrown in forum Capturing and VCRReplies: 3Last Post: 13th Jul 2011, 10:07 -
Films onto disc
By Pumkinhead in forum Newbie / General discussionsReplies: 3Last Post: 19th Aug 2010, 05:00 -
I want to be able to burn these films to DVD, with their subtitles.
By KKPHM in forum SubtitleReplies: 15Last Post: 17th Mar 2010, 12:49 -
Hello! How to convert my films to DVD?
By breng60 in forum Newbie / General discussionsReplies: 5Last Post: 1st Jun 2009, 11:01 -
Is there a portable player for torrent downloaded films, no converting?
By bungo in forum Portable VideoReplies: 8Last Post: 20th Oct 2007, 13:12
