I was down my local COSTCO today, and say sony discs priced at 12GBP for 2x5packs jewelcased. They came in two varities, one MAde in Singapore described on the cover as 1-4x discs with the code 5DMR47N2.
Made in Singapore Front:
Made in Singapore Back:
THe other option were 2x5 Packs jewel cased Made iN Taiwan, descried in the COSTCO blurb as 2x discs with the code 5DMR47A.
Made In Taiwan Front:
Made in Taiwan BAck:
Scans are from the boxes (not jewel cases)
One of the packs is going back, but before opening i want to deicde which will offer better quality i know the 2x and 4x dsics are the same price, but dont mind sacrificng spped for quality. Does anyone know the media codes of both discs (the media section wasnt too good) if the are both sony made, then which offers better quality (i know japan discs for maxells and imations come above the taiwan discs but have little knowledge of optical disc makers in singapore.
Thanks all
Actually you can find your answer from the DVD Media database.
The 4X made in Singapore DVD-R discs are manufactured by Mitsubishi Chemical with the Mfr ID of MCC 01RG20:
https://www.videohelp.com/dvdmedia.php?selectmedia=398#comments
The other pack with no speed rating was probably manufactured by LeadData in Taiwan with the Mfr ID of SONY, the same discs were also manufactured in Austria:
https://www.videohelp.com/dvdmedia.php?selectmedia=95#comments
The newest Sony 4X DVD-R discs are manufactured in both Taiwan and Austria with the Mfr ID of SONY04D1:
https://www.videohelp.com/dvdmedia.php?selectmedia=1019#comments -
Thanks Synergy, LEADATA thats poor, i know theyll being going back. The Singapore discs look, good, ill probably order some maxells in a few weeks, the sony can tide me over
Media Made in India, Thailand, China or Taiwan.
By DroWni in forum MediaReplies: 1Last Post: 16th Sep 2008, 14:45 -
Verbatim still making DVD+R DL in Singapore
By jman98 in forum MediaReplies: 1Last Post: 15th Mar 2008, 14:55 -
Where can I buy (in USA) Verbatim DVD+R DL made in Singapore?
By JohnnyBob in forum MediaReplies: 12Last Post: 10th Dec 2007, 12:34 -
Are Verbatim's 'Made in Taiwan' discs...
By dvdashot in forum MediaReplies: 2Last Post: 8th Aug 2007, 14:55
