    Jan 2004
    Australia
    I had downloaded some video clips from the net and i would like to dedicate some video clips to my girlfriend but I dont know how to insert some words with before the file or video starts.
    If any one know how to do this plz help
    Sup ESE
  2. If you are using MSP7 download the user manual and look at page 129, that is, as long as the online manual is numbered the same as the hard copy (if not look up voice over in the index). This page shows you how to insert a vioce file, you will probably have to use a solid background or pic to voice over though.
    "Simply simplicity"
  3. Not sure if you want voice, or just some text. I'm also not sure if you're burning (S)VCD or DVD, however...
    I did something similar by making a .bmp or .jpg with my words on it, then using that as the background for the title page, using nero to burn it.
    Cheers, Jim
    My DVDLab Guides
