sync problem with TMPGEnc DVD Author
Before i authorize the file is fine but after authorizing when i play the put file in windvd the audio is out of sync.
please help
Results 1 to 13 of 13
I am having the EXACT same problem. I just checked the "What DVD authoring tool" forum and there are like 42 people who use TMPGEnc DVD Author.
Has no one else had this experience/problem? -
How are you creating MPEG-2 files? Directly from an MPEG-2 capture card? Hardware or software?Originally Posted by Zeronada
What bitrate is the video?
VBR or CBR?
What format/bitrate is the audio? -
i'm having the same problem.
using TMPGenc DVD author 1.5.15.49, importing MPEG1 files (all standard 352x240,29.97fps,1150k). some files in the set work perfectly, some don't.
i thought it was a sample rate problem, so i tryied re-encoding the audio and manually converting to 48k and re-multiplexing back in, but then TMPGenc gives me a bufferunder-run error ever time, and the VOB file is still out of sync. any ideas? the MPG file may be corrupt somehow, but plays ok before authering. i'm willing to try another authoring tool, but DVD-labs doesn't handle MPEG1 files properly, and some others aren't downloadable.... -
A: with a PVR 250 card and SnapStream
4000000 bits per second
VBR or CBR?
CBR
48000 hertz
224000 bits per second
See anything that looks wrong? -
Looks OK.Originally Posted by Zeronada
I just did a test. I captured about an hour of video, but at a lower bitrate (4800 - 6200 Kbps VBR) and made some cuts and created some chapter points in TMPGEnc and it created a perfect VOB. So I'm wondering if the higher bitrate of the file I had a problem with is the problem...which it shouldn't be.
Are you trying to use multiple files to create one DVD? This test I just did was using only one file...I'll test that next.
Well, that didn't work. I tried doing the cuts with only one file -- the higher-bitrate original that gave me problems earlier. Still have sync problems.
Next I'll try using only one file with no cuts or chapters.
That didn't work. Still losing audio sync.
I'm going to try another source at the higher bitrate to see what happens. I'll let you know. -
Mr. Mungus,
After a lot of searching on the net last night, I think I have a solution.
While my solution was found on a site that mostly concerned SnapStream (the software I use to get my caps) the *idea* behind the problem may still apply to the problem we are having.
Here is the link to the thread I found: http://discuss2.snapstream.com/vb/showthread.php?s=&threadid=8111
It seems that when you go about slicing the commercials out of a cap, the program you are using (or your capture program) may be encoding the new files with a slightly different audio format than what DVD Author wants to use.
The solution that the people on the SnapStream thread propose is that you use Womble to cut out your commercials and reencode your show (takes about 5 minutes)
I tried it last night with a clip that was already messed up, and it actually fixed the file well enough so that the resulting DVD was just barely out of synch. Today I'm going to try it on clips that I have not already edited to see if they result in perfectly synched audio clips.
I'll post my results. -
MPEG-vcr seems to help ... i posted elsewhere about how to fix/mux then re-sync the MPG1 files i've tried, which seems to work so far.
https://www.videohelp.com/forum/viewtopic.php?t=201839
https://www.videohelp.com/forum/viewtopic.php?t=201659 -
Hmmm. Then what I'll do is take a closer look at the audio on the original files vs. the audio on the resulting VOB files. I'm still thinking it's bitrate-related, though, as I think I can successfully create a VOB file with good sync as long as the VBR bitrate is betwee 4,000 and 6,000 Kbps. I'm doing another try now to see if I can consitiently encode a file at that bitrate.Originally Posted by Zeronada
Thanks! I'll check it out.Originally Posted by FuzzyLemming
the above method i posted seems to work for 'shifted' time sync problems. for progressive sync problems (at least for my MPG1 files), this sample rate fix seems to work: http://club.cdfreaks.com/showthread/t-59487.html
Ugh. I don't want to do any fixing.Originally Posted by FuzzyLemming
Anyway, I was able to get a good VOB just now by using 4000Mbps CBR instead of VBR. I don't know if the problem is with the VBR files that the PVR-250 is creating or not.
Correction: I created VOBs using Ulead Movie Factory and they did work in the W2K DVD Player.
Could the problem be TMPG DVD Author trying to encode VBR? -
Update: According to this guide https://www.videohelp.com/tmpgenc.htm#problems TMPGEnc DVD Author has a problem with VBR MPEG-2 files that have MP2 audio (DVDLab appears to have the same problem since it's giving me audio sync problems, too).
Did another test and Ulead DVD Movie Factory appears (again) to be able to create DVDs with perfect audio sync using the same source files as TMPGEnc DVD Author and DVDLab.
Questions:
1. Capture programs for the PVR-250 that will let me capture to ACM or LPCM audio instead of MP2?
2. Authoring programs other than Movie Factory that will let me use VBR MPEG-2 files with MP2 audio as the source and maintain lip sync?
3. A quick way to convert an MPEG-2 file's MP2 audio to AC3 or LPCM (or maybe a slow way while authoring)?
TIA
TMPGEnc DVD Author 3 gradually loses audio sync
By timmus in forum Authoring (DVD)Replies: 1Last Post: 6th May 2009, 18:24 -
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 17:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
