By accident (yes I'm an illiterate also when it comes to shooting with a cam) I found out that not using "auto features" like "SteadyShot", autofocus and so on the quality of the DV footage increases (sometimes quite substantially) resulting in less blockiness when encoding to SVCD (haven't tried VCD but the result should be the same). This is because, at least on my cam, which is a Sony DCR-TRV11E, the SteadyShot uses part of the pixels to compensate for shaking leaving less pixels for what you really is trying to catch. The draw back with not using SteadyShot is, if you don't have the option to use a tripod (very good investment), that you have to be quite steady/make slow movements otherwise the shaking can be quite obvious (but at least less blocky).
There is a forum which deals with the VCD pre step, i.e. DV footage it self, and it can be found at www.dv.com/db_area/cgi-bin/Ultimate.cgi?action=intro&BypassCookie=true.
I suppose this is the trade off between steady images and image quality...
Apart from a tripod, you can also buy this handheld balancing system thing that helps removing hand shaking as well.
On more expensive models of Sony camcorders (and presumably other brands too), the "SteadyShot" function uses a physical optical system rather than the electronic system on lower end models. This allows for less shaking without loss of video quality.
Regards.
Michael Tam
w: Morsels of Evidence -
My TRV120 has 470kpixels which is more than needed for
720x480 image. The border area is used for image stabilisation.
I seriously doubt that they resample the image from the CCD.
I don't say you are wrong, but there is probably another reason for
quality improvement when stabilisation is not used.
I will definitely try it.
PS:
I found that buying 12 hour battery stabilises the
image - it is so heavy that shaking decreases
<font size=-1>[ This Message was edited by: DVman on 2001-07-11 05:56:27 ]</font>
<font size=-1>[ This Message was edited by: DVman on 2001-07-11 05:56:50 ]</font> -
DVman,
I'm not sure, but I think that this has to do with the various ways Sony does the image stabilisation.
Some models have the oversized CCD whose "border" is used (thus no/minimal loss of quality).
I believe some cheaper Sony models do in electronically only.
Regards.
Michael Tam
On 2001-07-11 05:55:03, DVman wrote:
PS:
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
great tips everyone!! keep it up!!
Converting YV12 to anything else causes inexplicable blockiness
By Asterra in forum Capturing and VCRReplies: 13Last Post: 19th Apr 2011, 06:02 -
Increased picture quality with increased framesize (during transcode)..?
By Gew in forum Capturing and VCRReplies: 1Last Post: 31st Mar 2009, 11:04 -
Blockiness in a running water scene
By Umen Pich in forum Video ConversionReplies: 10Last Post: 20th Nov 2008, 10:32 -
Does increased memory help in Video Capture ?
By VEBouto in forum Newbie / General discussionsReplies: 18Last Post: 14th Mar 2008, 06:51 -
Vegas rendering problems, clips with increased speed turns out black
By sebaa in forum EditingReplies: 0Last Post: 10th Feb 2008, 14:24
