I used TMPEG to make the Divx into a MPEG 2 then I authored it with TMPEG DVD Author, then burned it with TMPEG DVD Author and when I play it back its rather jumpy any ideas why?
Results 1 to 12 of 12
Was it jumpy before you edited it, if not was it jumpy after you authored it but before you burned it.
Check your framerate, what are you coming from ntsc ? going to say pal ? -
anyone I have to burn it to a DVD R and I dont want to burn it unless I can get it fixed right
note this is for my brothers dvd player and it only plays -R and -RW and I used a +RW to test it out to make sure that it will work fine and thats when I found out that it jumps. -
Try frame serving it with Virtualdubmod to TMPGEnc. I Had a similar issue with an Xvid avi.
Hope this helps -
He said that it is fine after authoring only goes wrong after he burns it.Originally Posted by Turtle49
Change your media and or burning speeds. -
Ignore turtle, your problem is not your conversion method. His method may alleviate your problem if it was skipping AFTER you authored. Your authoring method is fine as it plays ok. Check your media.Originally Posted by thegame310
my media is fine it did it with Memorex DVD+RW and Maxell DVD-R i really don tknow what to do it seems like I just cant make a perfect dvd
what speed are you burning at? have you tried a different burning app? you might not think these things matter but it can be the difference between good results and bad. try burning the video ts folder with nero.
Divx playback problems on DVD Player
By pblunn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Feb 2008, 02:02 -
Problems converting DIVX files to DVD
By Jack_Dante in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2007, 13:12 -
Divx 2 DVD Problems
By KilinKind in forum Newbie / General discussionsReplies: 8Last Post: 8th Aug 2007, 08:03 -
DIVx to DVD problems
By ulm4lyf in forum Newbie / General discussionsReplies: 8Last Post: 17th Jul 2007, 00:26 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 14:57
