i am a graphic designer just getting into the video/dvd world. i have a the sharp camera listed above and it's about 2 years old. when trying to transfer video to my computer via firewire, there is intermittent artifacts in the video, not only on the computer as i'm transfering but also in the viewfinder of the camcorder itself. i have tried several different tapes (and brands) and i'm still getting those darn squares in the playback. they never occur in the same place. i freelance at a video production studio and one of the techs suggested the camcorder just needed a good cleaning. so i bought one of those cleaning cassettes, but the problem isn't fixed. i definately think the error is with the camcorder, not my computer, because it happens whether the camcorder is connected to the computer of not. i'd love to just trash this camcorder (it's a piece of crap) but i really don't have the funds to buy a new one right now. any suggestions? thanx!
ps.. if "artifact" isn't the correct term, forgive me. this stuff is all new to me.
This camcorder is well known for doing this. A cleaning tape would not do the job. You need to get yourself a bottle of rubbing alcohol and bunch of Q tips. Open the tape compartment and wipe off the rounded play head pretty aggressively from every angle you can get to it.
In the future, use just one brand of tape. Do not mix tape brand. Each brand has its own tape lubricant and they smear on the play head, even though that is not visible to the naked eye. -
PS - if that doesn't work, get a blank tape. Let it play from start to end a couple of times.
thank you SO MUCH for your reply.
i regret every buying the stupid camcorder but it seemed like a pretty good deal (and it got good reviews) at the time. but i have to make it work for now if i can.
thanks again.
Digital 8 playback and deterioration
By Abigail Smith in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Nov 2010, 17:08 -
Digital audio crossover for DVD playback?
By bibo01 in forum AudioReplies: 0Last Post: 25th Oct 2009, 11:47 -
Digital Frames / Video Playback?
By therock003 in forum Portable VideoReplies: 3Last Post: 24th Jun 2009, 12:13 -
Capture Sharp Viewcam Hi8 with WinTV-HVR-1800
By Rotramel in forum Capturing and VCRReplies: 8Last Post: 20th Apr 2008, 09:25 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19
