problem is solve, but......a new one comes out..........After I convert the movie, there's no audio........the avi I got here has an audio, but after converting it, there's no audio......I turn my speaker and test other movies and the sound was great, but the avi I convert, sound is definitly nothing....
Use G-spot to determine what kind of audio your AVI has. If it's mp3 then open your AVI in Virtualdub. If you get a variable bit rate error then that's your problem. However itt might have AC3 audio instead. Either way, what you can do is set the video menu(in Virtualdub) for "Direct Stream Copy" and the audio menu for "Full Processing Mode", then save your AVI(with a new file name). Then run the new file through AVI2VCD.
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 22:18 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
Problem converting avi to dvd(mpeg)
By Wackster in forum Video ConversionReplies: 6Last Post: 14th Jan 2008, 22:49 -
Problem when converting DV AVI files to MPEG
By MI6 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 14:34
