Hello, I have been burning vcds for quite a while, but i recently got a dvd burner. A friend of mine told me it was possible to put up to 4.7 gigs (instead of the 120 minutes) of video files if they are in VCD form (im assuming he meant mpeg). I have looked at a few guides on this site but it just confuses me more. Im just wondering what media, burner, burning rom, etc. to use, and how to do this.
Thanks Alot
Results 1 to 10 of 10
Ok, after reading those I still have a few questions:
1. It seems that all these guides deal with VCD's that have already been burnt to CD, in my case, I'm using files that are on my HDD. So, for example, if I am using [url=http://www.lordsmurf.com/convert/vcdtodvd/vcdtodvd.htm]LordSmurf's VCD to DVD Guide[url] , could I just skip the file extracting step and go right to TMPGEnc DVD Author?
Hrmm, I guess I only had one question
Thanks Alot! -
alrighty, another dumb question
demultiplexing, no idea what that is or how to do it
thanks alot! -
Demultiplex means to separate the audio and video streams. You need to demux your VCD file so the audio can be transcoded to 48 kHz.
You can use TMPGEnc to demux any file. It's in the MPEG Tools section of the File menu.
Demux to separate, mux to bring together, remux to bring together again. Know mux, and you will know DVD.
I am one with the Mux
I think
I have the files de-muxed, and the audio has been converted to 48kHz, i muxed them together and it seems to be ok so far, my dvd burner will be installed by the end of the week, ill let you know if i am succesful or not =D
Thanks Alot! -
Sounds like you were all muxed up and now you're de-muxed!Originally Posted by Cpt. Usopp
"Art is making something out of nothing and selling it." - Frank Zappa -
I have been working on doing something very similary to this. As far as I can tell, TMPGEnc DVD Author will automatically re-encode the audio for you as long as the MPG file you supply is a valid VCD file (352x240, 41kHz Audio ...) Just a thought, that can probably save you some time. This topic might be of use to you:
https://www.videohelp.com/forum/viewtopic.php?t=192510&highlight=
-Eric
Convert AND Combine Multiple VCD DAT files to Single Divx/Xvid file
By GrayStrickland in forum Video ConversionReplies: 4Last Post: 17th Aug 2012, 13:23 -
Remove multiple tracks from multiple MKV files
By accoutabc in forum Video ConversionReplies: 3Last Post: 7th Aug 2011, 12:50 -
Merging/Converting Multiple M2TS files to MKV With Multiple Audio Tracks
By Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 16:45 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28
