just installed iLife 4, and when I launched iDVD it said that my mac does not have a supported SuperDrive (I have a external pioneer 106). It also says that I can work with iDVD projects but will not be able to burn.
any patches out there yet??
or should I just use DVD Studio Pro?
that seems to be fine without a superdrive.
(any FREE tutorials out there)
thanks
derek
thanks
derek -
I went fiddling around in iDVD4's .app package and saw nothing that would enable the BURN button.
When you make a project in iDVD4 then save it, you can open it in DVDSP2 but your theme comes up missing and any video you placed into a drop zone will look oddly placed.
When Toast 6 was coming out, one of its new "features" was to be the ability to work with iDVD projects (or was that iMovie projects?) but I havent seen anywhere how to do this...
As a side note, in iMovie4, you can capture fairly high quality video into it from your iSight cam. I tried that this morning, it was sweet! Now I just gotta learn how to use iMovie... -
Originally Posted by AntnyMD
I movie is fun, i fooled around with it a bit its pretty straight forward, should be an easy learn for you
IDVD themes
By greeneyes21 in forum MacReplies: 3Last Post: 21st Jan 2010, 20:05 -
iDVD and subtitles
By Sgaar in forum MacReplies: 4Last Post: 4th Jan 2009, 22:37 -
No Audio in iDVD
By The Monkees in forum MacReplies: 8Last Post: 12th Feb 2008, 18:35 -
MPG's in iDVD
By The Monkees in forum MacReplies: 12Last Post: 10th Jan 2008, 17:56 -
Latest Patches Cripple IE7
By MOVIEGEEK in forum ComputerReplies: 10Last Post: 22nd Jun 2007, 01:14
