Last night while doing my usual meandering around the internet, I heard one of my fans dramatically increase in speed ! I went to task manager and found my CPU usage was at 100%, I closed all running programmes but it was still at 100%.
So I shut my PC down and rebooted, and all was fine untill I opened "My Music" folder within "My Documents" and the CPU usage shot up again to 100%.
After much fiddling about this only seems to happen when I open My Music. I've done all the usual things, virus scan, adaware scan, defrag etc but it is still happening.
First thought was the CPU was going belly up, but I did some authoring on some VHS I'd captured, which I know ups my CPU usage. It ran at 95% + while I was authoring, then when I'd finished, it was back to normal.
I opened loads of folders, programs etc., played a DVD all at the same time, no problem, but the moment I opened My Music, wham 100% ! Also my PF in task manager went over 800MB.
I have a horrible feeling this could be bad news.
Any ideas
PC problems ? then visit www.ezpcforum.com
Its a known bug in WinXP. Happened after one of MS's famous security features. Selecting cerian file types in Explorer cause CPU useage to go to 100% (and often stay there till the next reboot).
Don't know if there is a fix available for it yet though. -
Originally Posted by bugster
Thanks for your repliesPC problems ? then visit www.ezpcforum.com
CPU to MB Compatibility
By jollyjohn in forum ComputerReplies: 2Last Post: 21st Mar 2012, 03:19 -
New CPU
By Sckinhunter in forum ComputerReplies: 9Last Post: 13th Apr 2011, 01:10 -
CPU
By HotDamn! in forum ComputerReplies: 7Last Post: 17th Dec 2009, 01:21 -
CPU Temperatures Going Up
By wulf109 in forum ComputerReplies: 2Last Post: 8th Mar 2009, 13:45 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
