Hope this is in the right section this time........
Guys i have looked around at the guides and various other places but cant quite find help for what i`m trying to do
Simple authoring using Tmpgenc is fine but what i want to do is add Extras and scene selection to the film
i have created the scenes from the film no probs and have imported the extras that i want to include again no probs
its here on in i`m struggling , in the source setup do i need 2 or 3 tracks
1 for the main film
2 for the extras
3 for the scenes
this is how i have it but maybe thats wrong
its how to set the menu system to be able to select from a first page thats getting me confused
if i give an outline perhaps someone can advise
1 initial front screen with 3 options on
2 No 1 option Play movie
3 No 2 option select scenes from film
4 No 3 option Select Extras page
all pages to have return options to first screen
Thanks guys
Thankx for your reply m8
i eventuallly setled for a copromise , i didnt get exactly what i wanted but it still works , heres what i did
in source setup i imported the main film as a track and then created another track for the extras i wanted to include , then i created scenes from the main film , then i went to edit menu theme and selected the theme with the three book type things stood up , the left hand window now shows 3 menu items , main menu , track 1 menu and track 2 menu , track one menu when clicked shows the scenes i had created and a play button , bottom right , so i changed that to a picture of the main film , when clicked it acts the same as the play button and plays the main film , track 2 when clicked shows the extras i imported and apart from a bit of txt here and there can be left alone , in the menu display settings i selected automatic settings in the general tab and use motion menu under motion menu tab , the other settings i used there were the top two track thumbnail and chapter thumbnail , they work realy well and because i have about 14 scenes and also 14 extras when they are displayed on a single page they look great ,
so i started wanting a three option front screen but ended with just the two , however all i did was rename the top picture in main menu right hand panel as scene and main film selection and the bottom picture as extras
my advice to anyone using Tmpgenc is get the project close to finish and then burn it and try it coz its damn hard to figure out what and how its all gona work just from your monitor
now all i gota figure out is setting audio to the menu`s i know i have seen a piece here somewhere about it just gota find it
TMPGEnc Authoring Works 4 Menu Help Needed
By VOYAGER2009 in forum Video ConversionReplies: 1Last Post: 15th Apr 2011, 12:37 -
Menu question re: TMPGEnc Authoring works 4
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 9th Jun 2010, 07:32 -
DVD menu software to import into TMPGEnc Authoring Works 4
By mobie29 in forum Authoring (Blu-ray)Replies: 0Last Post: 28th May 2010, 13:34 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 02:24 -
TMPGEnc Authoring Works 4 Single Menu
By Sakuya in forum Authoring (DVD)Replies: 3Last Post: 22nd Dec 2009, 02:04
