I'm trying to decide on a motherboard. It's either an Asus A7V600:
http://uk.asus.com/prog/spec.asp?m=A7V600&langs=11
Or an Asus A7N8X Deluxe V2:
http://uk.asus.com/prog/spec.asp?m=A7N8X%20Deluxe&langs=11
I have used the N8X before and they are rock solid motherboards, but I am tempted to go with the KT600 because it's cheaper and looks to offer the same level of features.
I'll be overclocking using this motherboard.
Thanks for any thoughts,
CobraDMX
I'd post this at http://forums.amd.com/index.php?act=idx. They could answer that question
I have the Nforce chips on my MB and I like it so far. I have a Nvidia video card so my thought was everthing will work together. 808smokey has the right idea though, ask the overclockers and reviewers. I went with a Gigabyte board because it was cheaper than the ASUS. If you believe the ads, the Nforce chips are a step ahead of the KT600 chips.
