I have a SVCD download that I cannot open in TMPgenc as it says it is unsupported, I have tried increasing the direct reader option but that doesn't make any difference.
Does anyone have any ideas please?
Well, first I suggest that you copy the AVSEQxx.MPG file(s) from your SVCD to your hard drive for fasting file reading access. The file(s) are in the \MPEG2 directory of the SVCD. Note: Movie files from VCD/SVCD are NOT standard MPEG-1/MPEG-2 because they were modified for VCD/SVCD authoring (VirtualDubMod detects this). You may want to convert these files to standard MPEG usin IsoBuster or VCDGear for more compatiblity with video software in general.
TMPGEnc is a great product, but it sometimes has problems opening movie files. So, you can try to open the .MPG files with VirtualDubMod, DVD2AVI, or AVISynth. All of these can understand MPEG-2 video and AC-3/Dolby audio and MPEG audio. I think the first choice here is the easiest/simplest and AVISynth is the most complex. See the graphic screenshot of VDM below. Check the "Tools" section of this website to get the software. Check the "Guides" section of this website for info.
After opening the SVCD/MPG file, what do you want to do with it? Convert?
Also look on these websites for more info:
http://www.doom9.org/index.html?/vdubmod-procedures.htm
DVDRHELP Guides
http://virtualdubmod.sourceforge.net
http://arbor.ee.ntu.edu.tw/~jackei/dvd2avi/
dont take this the wrong way but it may not be in svcd format even though it says it is
nuwave22 -
TMPGEnc may need a plugin for MPEG-2/SVCD files.
See this post.
https://www.videohelp.com/forum/viewtopic.php?p=790736#790736
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 18:23 -
Tmpgenc Plus & TMPGEnc Batch List Creator help Please
By VOYAGER2009 in forum Video ConversionReplies: 2Last Post: 4th Jul 2010, 07:57 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40
