Hello all many thanks in anticipation for your help.
I have read 1,000's of posts and tried a lot of routes to achieve my aim and to date mixed success.
So have a number of queries that I would appreciate a view on!
1. How can I determine the origin of the source file (AVI) i.e PAL etc.? There is a programme callled G-SPOT but this appears to be exclusively a Windows based programme.
1.(a) Re: The above - or can I just select "Unspecified" in the frame rate on the VIDEO options for FFmpegx ?
2. Using FFMPEGX - appears to create 2 files - Video and Sound after the lengthy encoding process - when exporting these to TOAST Version 6 - why does TOAST start to encode again? Surely if they are encoded files this is unecessary.
3. Using a post from this forum by WIZEMAN - some very user friendly instructions for FFMPEGX which I followed to the letter however when it comes to CHAPTER 3 - MPEG 1/4 I get completely lost it asks me to click buttons and select options I simply don't have i.e HIGH QUALITY option - for the record my FFMPEGX has VIDEO, AUDIO, FILTERS, OPTIONS and TOOLS but no MPEG 1/4.
4. My early attempts have produced a) VCD - that DVD players reads but no Video or Sound just recognition that there is a 43 minute file. b) VCD that plays good video but the sound sounds like it was recorded in a bath tub! Presumably this is relatively easy to fix changing mp2 file bitrate etc? and a VCD that worked brilliantly although this was from a MPEG source file.
5. Dowloading AVI files - some I can play automatically in Q player (PRO) however some I have to use VLC - why is this?
6. Am I taking the best route - FFMPEGX then TOAST?
7. Should I give up as have seem some posts saying that MAC OS X simply can't do this?
Hope this makes some sense and thanks again in advance.
Richard.
Ok have played with the programme and almost there!
Have managed to produce 2 workable bin/cue files that are both visually and sound fine! However the resulting MPEG has an approximate 28 second delay on the sound (quality perfect) this happens from both MEPG file created by FFMPEGX and also when I attempt to create using Toast through the bin/cue copy function.
I can't see the word for the trees! How do I realign the audio onto the visual?
Thanks.
Richard.
Newbie2Guest
I was having a similar problem. Using VLC to check the intermediates, I determined that the issue came in the post processing phase (ffmpegx made the 3 SVCD movies fine but creation of the bin/cue created the problem). So now I have successfully done this process: 1. avi or mov into ffmpegx 2. select SVCD option on bottom 3. In tools menu, unclick the "author as SVCD" 4. click encode 5. use sizzle to burn VCDs then from the mpeg2s that are generated.
Newbie HELP!! DVD to AVI
By Bolisk in forum Newbie / General discussionsReplies: 2Last Post: 11th May 2010, 23:36 -
Newbie :: AVI audio editing . . . how?
By pretzeltop in forum EditingReplies: 8Last Post: 25th Jun 2009, 11:00 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37 -
Very Newbie Conversion -- Vob to Avi
By dadada_999 in forum DVD RippingReplies: 3Last Post: 2nd Dec 2007, 12:51 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 08:34
