Results 1 to 11 of 11
  1. This is the first time I have come across this problem with R.C.E and have included the screen image
    What is it and how do i backup region free ?
  2. Specify the region of the DVD...
  3. I'm sure someone can give you a more technical answer, but in these situations I usually give it a try and burn it to an RW disk (actually, I burn everything to one first just to make sure it's going to work right). Then if it doesn't work, try it with the other setting.
    Anyway, that's my approach - trial and error, within limits, of course....
  4. Yes ok but I dont know the region as i do not have the case.
    also could anyone explain what this protection is ?
  5. Originally Posted by paul_pompey
    https://www.videohelp.com/glossary#Region%20Coding%20Enhancement
    DVD Decrypter will tell you the original region.
    Isn't it a FOX movie?
  6. The movie is "Babe" you know the one about the talking pig !!
  7. Have just used dvd decrypter and it is telling me it is region 2 and 4 so any idea as to how I use shrink to backup this movie ?
  8. what version of dvd shrink are you using? i think i remember hearing something about a version prior to 3190 having problems with RCE.. if you're not using 3190, you might want to download/install & rerip the disc.
  9. I have used 3 versions of shrink 2.3 ,3.0beta 5 and also 3.1.4 the latest version
  10. jeex said: earlier DVD Decrypter versions had problems with RCE which I can second.
    I would use DVD Shrink 3.xxx and specify region 2
    (you could try it on a rewritable disc first as Johnny said)
    The movies I have with RCE protection have only one region specified
    Yours has two: region 2 and 4
    Interesting...
  11. hi guys i've been using dvd shrink but for some reason towards the last 2 to 3 capters it freezes on some movies why is this?
    i've also tried to use dvd dycrpter 1st then back it up with shrink and some movies just freeze. ive tried dvd2one sucks cause it cuts parts
    help me
