hi,
I have a P4 1.5 256 etc, whe nI capture useing vidcap or virtualdub in regular capture mode I drop not a single frame but I need to capture more than 2 gig and when I use that feature in virtualdub or I use avi_io, I loose tons I cant figure it out if someone can help PLEASE. BTW the proccessor never redlines. I have dma on. win ME
so you're saying you lose tons of frames if you enable mutli-segment capturing? if so, check where your spill drives are located (in virtualdub). it might be spilling to a different hard drive, or no drive at all! =|
jsut a follow up, I once was able to capture segemented files in viddub useing "compatibility mode" - it worked great with no dropped frames, but Ican't seem to do it again If you have any suggestions please share them THANKS
OK dont ask me why (maybe you can explain it) but when I tried vidcap32 which also creates segemented video files, it works with no problems, now I just need to figure out how to combine the adio and video files (vidcap32 creates seperate files) any help or links is appreciated
I use tmpgenc to join video and audio files. On VIDEO, select the file where you saved it and on AUDIO, select the file where you saved it, configure and hit ENCODE. hope this helps.
DVD frame dropping.
By videosam in forum Video ConversionReplies: 20Last Post: 4th Aug 2010, 05:00 -
Dropping one single frame in a two hour capture?
By justin81 in forum Capturing and VCRReplies: 5Last Post: 13th May 2010, 10:38 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 07:55 -
Dropping frame with profile H.264
By n69 in forum Video Streaming DownloadingReplies: 2Last Post: 22nd Dec 2008, 22:41 -
is this pinnacle, dazzle or my new PC causing my frame dropping problems
By arthur1971 in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2007, 03:41
