    Mar 2001
    radcliff
    need help trying to convert a bin and cue file to mpeg to play on my windows media player. I tried to use vcdgear to convert it to mpeg but file comes up sayin bin afile not found in cue file. are there any suggestions
    canada
    Open the cue file to make sure it points to the right path to the bin file,edit the path if it contains directories that dont apply to your computer.You can also open the bin file without the cue file.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Try isobuster maybe.
    Mar 2001
    radcliff
    how does isobuster works in order for me to convert to svcd file and how do I edit a cue file because it is not pointing the bin file
    Mar 2001
    radcliff
    it says it is looking for a codec in media player any idea what codec it is looking for. i tried nimo and fddshow and neither worked any suggestions
  6. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Try here, the "Guides" section is a great resource.
