Ok, I have a slide show business, and part of my service is to put the slide show that I create using adobe premiere pro, onto a dvd.
The thing I am wondering is, since these slide shows are only about 300mb, can I somehow put them on a cd that could be read by the dvd player. this would save me alot of money. i tried making a vcd using premieres mpg encoder, but it would not read on my dvd player.
Closed Thread
There is a format called MiniDVD which is just that. A small DVD format file burnt onto a CDR. But, only very few DVD players will recognise and play MiniDVD format disks as it isn't widely supported. If you are doing it commercially, you'll probably get the majority returned as the customers DVD player can't read them.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
I did NOT double-post, BUT...
By Midzuki in forum FeedbackReplies: 1Last Post: 8th Mar 2008, 19:51
