I have some experience in burning bin/cue and ISO's but this format is new to me. I tried using DVD decryptor to burn this but the program would see the file in the browse menu but just wouldn't let me select it.
I also noticed that the .mds file is 0 bytes? I have a feeling this is the problem, but don't know where to go from here.
Are these files like a bin/cue where the cue is just information on how to record the other file? If it is could someone inform or direct me on how to create one of these?
Thanks for the suggestion, and I tried it but it said file is not recognized. But again in this program as well as DVD decryptor the file is recognized but not selectable?
Is it possible to create an .mds file much like a .cue file or is this way more complicated? I have no idea what I am doing here and any suggestions that are given I will try.
Thanks -
It looks like you have a bad .mds file, and no I'm not aware of any way to create a new one. What you can do is mount the .mdf file to the virtual drive that Alcohol created, explore that drive and copy and paste whatever files(you didn't specify the type of disc you have) you need to your hard drive.
how to play mdf file
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 2nd May 2015, 10:01 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01 -
ISO w/ .MDF file
By 3lutz3toe in forum MacReplies: 1Last Post: 5th Dec 2007, 14:22 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 02:52 -
extracting vobs from mdf files
By uglijimus in forum Newbie / General discussionsReplies: 7Last Post: 15th Jun 2007, 13:15
