How much do Divx and mpeg 1 or 2 encoding compare to each other. Does one take more processing power than the other. I can succesfully convert dvd's to divx files but when i try to get those divx files from my hardive back to mpeg or mpeg 2 the computer crashes. Does mpeg conversion demand greater processing power???. I am running xp home, athlon 2200+,512 DDR RAM, 64 MB Ati Radeon 7000, 60 GB~30available.
This should not happen under any circumstances, either you have bad ram bad disk or its too hot. Or your software is borked. Buy you said whole computer crashed?the computer crashes.
And dont rule out virii.Corned beef is now made to a higher standard than at any time in history.
That makes about as much sence as ripping a CD into mp3s and then taking those mp3s and burn CDs with them.
Ridicules!Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
yeah, the whole comp crashes. I can't even move the mouse pointer on the screen. I then have to press the reset button on the pc tower.Originally Posted by RabidDog
For those of u who aer thinking why i go dvd to divx to mpeg, i dont. i have some divx files on my hdd and would like to get them into mpeg to burn them on a vcd or a dvd. Any ideas or suggestions.
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 11:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 19:59 -
problem converting mpeg 1 to divx
By goingape in forum Video ConversionReplies: 11Last Post: 9th Jan 2008, 14:17 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 03:16 -
Avi Or Mpeg to Xivd/Divx
By Castor troy in forum Video ConversionReplies: 2Last Post: 27th May 2007, 10:24
