ok im tryin to convert avi to vcd but all im gettin is a blank screen with audio. is there any way i can fix this?
Results 1 to 15 of 15
nuttin that helps my problem thereIf you get an error message when opening like file unsupported or can not open or is not supported
or you get an empty(black) video preview windowHello. -
i should of been more specific...ill encode a file and when i open the mpeg file i encoded it will have sound but no picture. this goes for every single avi i have encoded...so i dunno whats goin on here
Did you even try to adjust the VFAPI settings in TMPGEnc Plus yet?
Hello. -
Have it your way then. Best of luck to you, though.
Hello. -
You have your solution, whether you want to use it not, is the issue.
Hello. -
thx tommy! it was vfapi...errr sorry i was such a pain its just i had no clue where the heck vfapi was located lol...well anyways thx for the help u rock
That's okay. Glad it worked out for you , though.
Hello.
DVD - No Sound after recording but picture OK
By kadirh2 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jul 2011, 12:32 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00 -
Sound but no Picture?
By Soulfinger in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 18:10 -
I have sound, but no picture?
By TSI_AWD in forum Newbie / General discussionsReplies: 1Last Post: 9th Nov 2007, 10:59 -
No sound but picture works
By tou in forum MacReplies: 6Last Post: 12th Oct 2007, 17:36
