Assuming Money is no object.
What is the best program for encoding AVI to M2V files.
I use TMPGenc at the moment but it is slow and i assume there are better encoders.
Does Adobe Premiere do the job of TMPGenc better?
Thankyou
Assuming money is no object, you need a hardware encoder. Premiere is editting software, it will encode but almost certainly uses something like CCE to do the work.
What plug in is the best to use with Adobe Premiere Pro.
If any one has experience of it i would be grateful if you would share the knowledge.
Thanks -
Canopus makes a hardware encoder called the DVStorm2 that is supposed to be The Shit when it comes to encoding.
At the prices they advertise ($1088 MSRP) it oughta be good. -
Canopus ProCoder for software.
Yeah, I think that cce 2.50 is better output quality from other cce versions,
but I haven't quite figured out how to apply the Matrix changes. They don't
seem to work.
In any case :P
-vhelp
Acer AX3 Opinions Wanted
By V Bot in forum ComputerReplies: 2Last Post: 22nd Jan 2011, 22:25 -
Just wanted to say hello...
By Novice2010 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2010, 12:20 -
Opinions wanted
By Nelson37 in forum Off topicReplies: 14Last Post: 31st Dec 2009, 23:29 -
Considering buying Oppo DV-980H or ??? Opinions wanted.
By Puppets86 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 20th Aug 2008, 15:52 -
Just wanted to say thanks!
By freebird73717 in forum FeedbackReplies: 0Last Post: 30th May 2008, 17:10
