  1. Hey there guys, I am using Adobe Premier 6, I need to know how you can do matrix-like effects, where the person or object freezes and the camera rotates around it...
    Ps: Like my pic?
  2. well for starters you can watcgh the documentary on the matrix, it shows exactly how they did that.
    anyway, i dont know much about adobe, but a shot like that isnt simple. if the whole thing is computer animated, well then you could just make the camera rotate around the subject, but if you want to do it with real cameras and real video, well taht aint easy. i advise watching the documentary, they had a bunch of cameras in a circle set up to take shots at the same time so essentially they have photos from all angles. then arrange them so taht they play to circle the subject.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can do it in vegas http://www.creativecow.net/articles/kumar_satish/vegas_morph/
    but you may be able to apply some of the same things to adobe ...
  4. OK, thanks...
