  1. I have been reading about the stand alone home players for divx and hopefully xvid and all the talk is if they will actually play xvid, which is a very valid question. My question is about the audio, there are so many different audio codecs that people have used out there where there is only a small handful of video codecs that have been used and xvid/divx probably make up 90% or more. this machine http://www.neustonusa.com/productinfo.htm lists that it plays xvid but for audio, this is what it lists
    Audio Decoding
    MPEG-1 Layers 1 & 2
    MPEG-2 Audio Layer
    MP3 & VBR
    Ogg Vorbis
    AC3
    PCM Wav
    I know that won't cover it all, I was hoping they would be using some sort of hardware decoding to do the audio instead of the correct codec so that it would be more compatible.
  2. That's actually quite an extensive choice of audio support, the only missing one would be AAC.
    The 'standard' (90%) for DivX/Xvid audio is MPEG1 Layer 3 (MP3). That's the recommended format if you want the maximum portability (think handhelds etc).
  3. ! would say if it does mp3 and ac3 then youve got about 98% coverage. mp2 is nice for R2 videos and Ogg vorbis is also good to have. regarding xvid playing I havent come across any xvid that wont play ... so again I think its a tiny few that you have to worry about.
    The electronic components of the power part adopted a lot of Rubycons.
