hi, i just finished authoring a dvd with tmpgauthor and would like to preview it to make sure everything is good before i put it on a dvd. i have power dvd, and whenever i select from hard drive and select an ifo file it wont play... ne body kno y, or am i just doin somethin wrong?
Did you make all the proper connections in your authoring software? I once imported all the videos, set the chapters, mapped the menu pages, but didn't set a FIRST PLAY item. Without it, your DVD won't play.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
In PowerDVD, try using its "file" mode instead of "disc" mode, then open the VIDEO_TS.IFO file of your DVD files set. I am mostly familiar with PowerDVD and WinDVD versions 3.x, but not 4.x.
You could get some DVD video filters from http://www.doom9.org/software2.htm (in the Filters section) and use IFOEdit to do the DVD preview/playback from your hard disk. IFOEdit can open any .IFO file.
Also check this forum post:
https://www.videohelp.com/forum/viewtopic.php?p=785619#785619 -
i am runnin power dvd 4.0, and yes i did select the option get from hard drive. i pretty sure i author it right because i have made another dvd in the exact same way, the only difference is that i was putting some music in my backgroud and wanted to make sure it worked before i put it on a dvd
I have Power DVD 4.0, the DELL build of it. same problem. I also can't get Media Player 9 to open IFOs created by TDA in file mode either, though it handles other IFOs just fine. use IMG Tools Classic to make an ISO image of your files and mount the image in Daemon Tools. Power DVD will play it fine from there. Also I've got the newest Nero Vision package with Nero's Showtime player in it. It opens the IFOs just fine from the Hard Drive.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06
