Please I need help with this problem. I cannot get audio to sync correctly. It is happening in the demux/mux of SVCD2DVD. I get this error:
WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Is their a setting or option in SVCD2DVD that I can use? I note you can manually resync audio if it is behind or ahead of the video. Does the info above give any indication as to how to work out what to actually input in the audio sync box???
Thanx. Your help will be more then valuable
CG
Results 1 to 17 of 17
I forgot to mention - I tried the so called sure fire way, it does not work. The results are exactly the same.
Chrissyboy Please help? -
Can you give details of the structure of your DVD? VTS's SVCD or VCD etc.
Sure can, I am putting vcd onto dvd, 9 episodes. Have tried it with just one episode but still the same.
Each one of the nine gives the same message in the log as posted above.
Hope you can help
Col -
The first tip i can give you: Getting vcd on dvd is harder then learning to walk. So take you time and try it over and over again.
Did you read the sticky about video/audio sync?Greatings,
Yf -
Hi yf2001usa, thanx for the tips. But I have been doing vcd to dvd now for a couple of years and it is only since i upgraded to svcd2dvd 1.5 final that the trouble has started.
I had no trouble with previous releases and was more then happy with the quality of the video and audio. But had nothing but trouble since the upgrade to the final version.
I have looked at the audio sync link you refer to and found again with conjunction with svcd2dvd the problem is the same (in that guide an older version of svcd2dvd is used).
By not using svcd2dvd at all but only using tmpg and tmpg dvd author i now find i have pefect vcd to dvd everytime.
It is obvious the problem is where svcd2dvd demultiplexis and then multiplexis the files as the files are fine before this having checked the original files and then the _dvd files it produces, the fault is always with the _dvd files.
It is a shame i really rate svcd2dvd but it is a more then obvious problem as I have seen countless posts and comments all with the same problem.
At least I am sorted now. Anyone experiencing the same problem please email me and i will let you know how I got around it.
CG -
I have bad sync problems with putting vcds on dvd. Some work, others do not (and there are more that dont work
First, I only used Tmpegenc DVDAuthor. The first DVD worked, all others were out of sync. Then I used Tmpegenc to convert VCD to VCD (just to be sure). Directly after converting they were out of sync. Then I tried the "Surefire" way, same result.
I narrowed the problem to the conversion of audio from 44.1hz to 48hz.
Every help is greatly appreciated.
Greetz, TheDoc -
Hi The Doc, I don't think you read the above post from me (the one prior to yours)....
Cgunn -
Im having the same audio sync problem with a vcd that is broken into 4 parts. What I did was save the bins to my hard drive and then inputted them into svcdtodvd. I tried this twice and twice the audio sync problems. No problems so far with svcd to dvd conversions....but this vcd...I have had no luck with.
Having worked very closely now with Chrissyboy over the past few days I can confidently announce that the problem with the sync issues has at last been resolved.
As originally suspected, the problem lay with the source material and not svcd2dvd. Having looked at files that are known to have sync problems, and with files that are ok the problem was clearly identified.
After banging heads together and isolating this, Chrissyboy has pulled all the stops out, and if you go over to: http://www.svcd2dvd.com/Guides/AVSync/default.aspx
and follow what is on that page you will get correctly finished files using svcd2dvd. Some third part software may be needed to re-encode certain files identified by virtualdub-mpeg2 as being out of sync.
I was only to pleased to write the (what has affectionately been called now) 'CG Method' and am pleased that this has worked for you in the time between sorting out the problem.
So at last we can all go back to using SVCD2DVD to create our dvd's. Follow the new guide there and use this before you go to produce your _DVD files, and you should not have any trouble or wasted time. I have tested this method out and it works.
Col -
Just wanted to add a little something, I tried converting a 4 disc vcd (no names mentioned my precious...) using svcd2dvd and got avsynch problems and as identified earlier, it occurs when the mpg files are remuxed. I did the same thing with the same source mpg files using tmpgenc dvd author and no avsynch issues at all.
Does tmpgenc dvd author work in a different way? i.e does it not demux/remux the source mpgs?. -
Hello. I had asked before if putting a mpg through Tmpgenc would make the picture any worse than the original. I too tried converting a 4 vcd movie...no names precious... and at first the first cd and the third cd were out of sync. Then I used the new method of running through Vir Dub and indeend a nice little program to check if your vcd is out of sync. So I had the bin files saved to my hard drive and svcd2dvd converted them into Mpegs for me. Then I dragged the Mpgs to Vir Dub and then took the ones out of sync and used Tmpgenc to fix that and then ran the four mpgs through svcd2dvd. i just checked it and ....wow....four vcd's on the dvd and they are all in sync. Great. Thankyou to Chrissyboy and C Gunn....I really couldnt have done it with out you smart people. Thanks.
reencoding video will always give quality loss.. With good settings you might not even see it but with bad settings you'll see it right away
Greatings,
Yf -
Little bit the same problem here on this side.
However, the, by SVCD2DVD created _DVD files are IN sync and the final result on the DVD is out of sync.
So to be clear:
AVI - in sync
converted to VCD - in sync
converted to _DVD - in sync
result on DVD - out of sync
this out of sync starts right in the beginning. It's not that the out of sync becomes more and more out of sync the longer you play the movie. I loaded the _DVD files into VirtualDub to check if they were indeed in sync. No problem detected there (and also not in mediaplayer)
so... somewhere... from _DVD to DVD it goes wrong.
here's my log file. 2 of the 3 files gave a problem. Both are previously converted from AVI to VCD using Mainconcept. One was allready converted to _DVD on a previous run (but after detecting the problem i decided to try again) and one was converted to _DVD on this run. The BIN file that was extracted worked fine.
Greetings
------------------ error log ---------------------------
Starting SVCD2DVD: v1.51.2.0
Begin time: 17:28:27
******** Ripping BIN images to get mpegs (VCDGear )
VCDGear 1.76 final build 031225 coded by Dracore (vcdgear@hotmail.com)
Testing and quality control by MACKerMD
Language: English
Version: 3.50 - Jan. 1, 2003
Translation by: Dracore
processing method :: (bin2mpg)
.bin src(In) -> F:\dvd2\CD_Image_File_CD2.bin
.mpg dest(Out) -> F:\dvd2\CD_Image_File_CD2.mpg
[CD_Image_File_CD2.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 830516260 bytes [06:35:60]
#searching...
1 track(s).
Setting read size to: 2352
Setting write size to: 2324
# Track 1 -> writing...
# OK!
Language: English
.bin src(In) -> F:\dvd2\CD_Image_File_CD1.bin
.mpg dest(Out) -> F:\dvd2\CD_Image_File_CD1.mpg
[CD_Image_File_CD1.bin] Detected sector size: 2352
# 0%
#searching...
Track 1: 833305060 bytes [06:51:60]
#searching...
1 track(s).
# OK!
(Total size: 1608MB, Duration: 00:01:34, Rate(MB/Min): 1,021.63)
Analysing File: F:\dvd2\snatch.mpg
++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
Analysing File: F:\dvd2\Hackers _ Takedown_DVD.mpg
++ WARN: mpeg stream contained no scan information (user) data
Analysing File: F:\dvd2\CD_Image_File_CD2.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
Analysing File: F:\dvd2\CD_Image_File_CD1.mpg
-->Processing 4 mpeg files.
############### New MPEG File ###############
Type: VCD
Horizontal Res: 640
Standard: PAL
Audio SampleRate: 44100
******** Demultipexing original mpg file
(Total size: 1370MB, Duration: 00:01:32, Rate(MB/Min): 884.91)
******** Resampling audio from 44.1 KHz to 48 KHz
(Total size: 157MB, Duration: 00:03:19, Rate(MB/Min): 47.27)
******** Multipexing elementry streams
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [???] File F:\dvd2\snatch_DVD.mpv looks like an MPEG Video stream.
INFO: [???] File F:\dvd2\snatch_DVD.mpa looks like an MPEG Audio stream.
INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [???] Found 1 audio streams and 1 video streams
INFO: [???] Selecting dvdauthor DVD output profile
INFO: [???] Multiplexing video program stream!
INFO: [???] Scanning for header info: Video stream e0 (F:\dvd2\snatch_DVD.mpv)
INFO: [???] VIDEO STREAM: e0
INFO: [???] Frame width : 640
INFO: [???] Frame height : 480
INFO: [???] Aspect ratio : forbidden
INFO: [???] Picture rate : 25.000 frames/sec
INFO: [???] Bit rate : 1700000 bits/sec
INFO: [???] Vbv buffer size : 79872 bytes
INFO: [???] CSPF : 0
INFO: [???] Scanning for header info: Audio stream c0 (F:\dvd2\snatch_DVD.mpa)
INFO: [???] MPEG AUDIO STREAM: c0
INFO: [???] Audio version : 1.0
INFO: [???] Layer : 2
INFO: [???] CRC checksums : no
INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [???] Frequency : 48000 Hz
INFO: [???] Mode : 0 stereo
INFO: [???] Mode extension : 0
INFO: [???] Copyright bit : 0 no copyright
INFO: [???] Original/Copy : 1 original
INFO: [???] Emphasis : 0 none
INFO: [???] SYSTEMS/PROGRAM stream:
INFO: [???] rough-guess multiplexed stream data rate : 1959544
INFO: [???] target data-rate specified : 10080000
INFO: [???] Setting specified specified data rate: 10080000
INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
INFO: [???] New sequence commences...
INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
INFO: [???] Scanned to end AU 147858
INFO: [???] STREAM e0 completed @ frame 147858.
INFO: [???] STREAM c0 completed @ frame 246428.
INFO: [???] Multiplex completion at SCR=532292608.
INFO: [???] Video e0: buf= 212063 frame=147858 sector=00621651
INFO: [???] Audio c0: buf= 1408 frame=246428 sector=00081981
INFO: [???] VIDEO_STATISTICS: e0
INFO: [???] Video Stream length: 1256795029 bytes
INFO: [???] Sequence headers: 9858
INFO: [???] Sequence ends : 1
INFO: [???] No. Pictures : 147858
INFO: [???] No. Groups : 9858
INFO: [???] No. I Frames : 9858 avg. size 26889 bytes
INFO: [???] No. P Frames : 39429 avg. size 10061 bytes
INFO: [???] No. B Frames : 98572 avg. size 6036 bytes
INFO: [???] Average bit-rate : 1699600 bits/sec
INFO: [???] Peak bit-rate : 2092400 bits/sec
INFO: [???] BUFFERING min 130 Buf max 134306
INFO: [???] AUDIO_STATISTICS: c0
INFO: [???] Audio stream length 165600292 bytes.
INFO: [???] Syncwords : 246430
INFO: [???] Frames : 246430 padded
INFO: [???] Frames : 0 unpadded
INFO: [???] BUFFERING min 15 Buf max 683
INFO: [???] MUX STATUS: no under-runs detected.
(Total size: 1393MB, Duration: 00:02:44, Rate(MB/Min): 507.03)
Analysing File: F:\dvd2\snatch_DVD.mpg
Type: SVCD
Horizontal Res: 640
Standard: PAL
Audio SampleRate: 48000
- Leaving Hackers _ Takedown_DVD.mpg alone. File has Nav Packs
Type: SVCD
Horizontal Res: 480
Standard: PAL
(Total size: 792MB, Duration: 00:01:00, Rate(MB/Min): 792.00)
(Total size: 58MB, Duration: 00:01:39, Rate(MB/Min): 34.96)
INFO: [???] File F:\dvd2\CD_Image_File_CD2_DVD.mpv looks like an MPEG Video stream.
INFO: [???] File F:\dvd2\CD_Image_File_CD2_DVD.mpa looks like an MPEG Audio stream.
INFO: [???] Scanning for header info: Video stream e0 (F:\dvd2\CD_Image_File_CD2_DVD.mpv)
INFO: [???] Frame width : 480
INFO: [???] Frame height : 576
INFO: [???] Aspect ratio : 4:3 display
INFO: [???] Bit rate : 2530000 bits/sec
INFO: [???] Vbv buffer size : 229376 bytes
INFO: [???] Scanning for header info: Audio stream c0 (F:\dvd2\CD_Image_File_CD2_DVD.mpa)
INFO: [???] Bit rate : 20480 bytes/sec (160 kbit/sec)
INFO: [???] rough-guess multiplexed stream data rate : 2735448
INFO: [???] Scanned to end AU 76881
INFO: [???] STREAM e0 completed @ frame 76881.
INFO: [???] STREAM c0 completed @ frame 128141.
INFO: [???] Multiplex completion at SCR=276795684.
INFO: [???] Video e0: buf= 237568 frame=076881 sector=00373272
INFO: [???] Audio c0: buf= 1216 frame=128141 sector=00030450
INFO: [???] Video Stream length: 749998264 bytes
INFO: [???] Sequence headers: 5326
INFO: [???] No. Pictures : 76881
INFO: [???] No. Groups : 5326
INFO: [???] No. I Frames : 5326 avg. size 31313 bytes
INFO: [???] No. P Frames : 20879 avg. size 13865 bytes
INFO: [???] No. B Frames : 50677 avg. size 5796 bytes
INFO: [???] Average bit-rate : 1950800 bits/sec
INFO: [???] Peak bit-rate : 2377200 bits/sec
INFO: [???] BUFFERING min 15 Buf max 160892
INFO: [???] Audio stream length 61508164 bytes.
INFO: [???] Syncwords : 128143
INFO: [???] Frames : 128143 padded
INFO: [???] BUFFERING min 19 Buf max 479
(Total size: 798MB, Duration: 00:01:22, Rate(MB/Min): 582.68)
Analysing File: F:\dvd2\CD_Image_File_CD2_DVD.mpg
Type: SVCD
Horizontal Res: 480
Standard: PAL
(Total size: 794MB, Duration: 00:00:55, Rate(MB/Min): 866.18)
(Total size: 60MB, Duration: 00:01:48, Rate(MB/Min): 33.07)
INFO: [???] File F:\dvd2\CD_Image_File_CD1_DVD.mpv looks like an MPEG Video stream.
INFO: [???] File F:\dvd2\CD_Image_File_CD1_DVD.mpa looks like an MPEG Audio stream.
INFO: [???] Scanning for header info: Video stream e0 (F:\dvd2\CD_Image_File_CD1_DVD.mpv)
INFO: [???] Scanning for header info: Audio stream c0 (F:\dvd2\CD_Image_File_CD1_DVD.mpa)
INFO: [???] Scanned to end AU 79562
INFO: [???] STREAM e0 completed @ frame 79562.
INFO: [???] STREAM c0 completed @ frame 132603.
INFO: [???] Multiplex completion at SCR=286424210.
INFO: [???] Video e0: buf= 220020 frame=079562 sector=00373679
INFO: [???] Audio c0: buf= 736 frame=132603 sector=00031510
INFO: [???] Video Stream length: 750683974 bytes
INFO: [???] Sequence headers: 5421
INFO: [???] No. Pictures : 79562
INFO: [???] No. Groups : 5421
INFO: [???] No. I Frames : 5421 avg. size 33275 bytes
INFO: [???] No. P Frames : 21476 avg. size 13350 bytes
INFO: [???] No. B Frames : 52666 avg. size 5384 bytes
INFO: [???] Average bit-rate : 1886800 bits/sec
INFO: [???] Peak bit-rate : 2362800 bits/sec
INFO: [???] BUFFERING min 15 Buf max 168643
INFO: [???] Audio stream length 63649924 bytes.
INFO: [???] Syncwords : 132605
INFO: [???] Frames : 132605 padded
(Total size: 801MB, Duration: 00:01:27, Rate(MB/Min): 548.87)
Analysing File: F:\dvd2\CD_Image_File_CD1_DVD.mpg
******** Creating DVD Folders...
Creating VTS #1
SVCD2DVD: DVDfolders
Generating DVD folders please wait....
-->: DVDFolders creating VTS
-->: VTS 01
STAT: Processing C:\Program Files\BadgerSoft\SVCD2DVD\dummymenuPAL.mpg...
STAT: Processing F:\dvd2\CD_Image_File_CD2_DVD.mpg...
!!!: GOP is not closed on cell boundary (may be non seamless)
STAT: Processing F:\dvd2\CD_Image_File_CD1_DVD.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
!!!: Audio channel 1 gap is negative (-17280) on title 1 chapter 2
Creating VTS #2
-->: VTS 02
STAT: Processing F:\dvd2\Hackers _ Takedown_DVD.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
Creating VTS #3
-->: VTS 03
STAT: Processing F:\dvd2\snatch_DVD.mpg...
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
ADDING PRE COMMAND!
-->: DVDFolders creating table of contents
scanning F:\dvd2\VIDEO_TS/VTS_01_0.IFO
scanning F:\dvd2\VIDEO_TS/VTS_02_0.IFO
scanning F:\dvd2\VIDEO_TS/VTS_03_0.IFO
-->: Creating menu for TOC
STAT: Processing C:\Documents and Settings\Henry1\Local Settings\Application Data\Badgersoft\DVD MenuMaker\1.0.1482.26149\38f6fc0a-dc2d-40c7-814a-82c579a6103a\menu.mpg...
(Total size: 4353MB, Duration: 00:09:34, Rate(MB/Min): 454.86)
============ Complete ============
============ Duration: 00:27:01 -
I have a question for CGunn regarding A/V Sync.
I read through your guide, and found it informative - I certainly learned something I didn't know before. However, I have to question if there are any ways around doing full re-encodes.
I mean, for example, did you know that Womble MPEG-VCR has a "MPEG Video GOP Fixer" that will fix GOP time code and audio PTS errors. Unfortunately, I don't know exactly what it does, so I can't say if it will be helpful here, but I'd love your opinion on it.
In theory, it seems that a program could look at the PTS values, and tell when a frame was dropped, and then insert duplicate frames to "fill in the holes" without doing any re-encoding. This would fix the streams, and then they could be demuxed and remuxed without leading to problems.
I would also like to point to the case where there is only one batch of skipped frames, say toward the end of the mpg. Then there is really no need to re-encode the bulk of the mpg. Re-encoding is so time-consuming and always leads to reduced quality, so aren't there other ways to avoid full re-encodes?
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
I've got a choice between clipping or bad sync, need a third option
By Peter84072 in forum Capturing and VCRReplies: 6Last Post: 24th Jun 2011, 13:03 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
dvdauthorgui bad lip sync problem
By prioryjim in forum Authoring (VCD/SVCD)Replies: 5Last Post: 2nd Dec 2009, 05:47 -
Bad audio sync with known good xvid files
By damax452 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 17:22
