I know a guy who is wanting to set up a server where about 5 other computers (off location) can access it whenever it wants. They mainly want to use it for Quick Books for their business. My question is....should they use PCAnywhere? Is this the best program for this type of project. Is there something out there that is better? Is it hard to set up?
Thanks for anyone that can answer my questions.
Hatz
Loves the funeral of hearts.....
i sure wouldn't have the companies accounting system online with remote control software on it ...
http://www.tightvnc.com/ is better control/features than pc anywhere but not as secure i suppose (unless SSH/OpenSSH is used, then its better) ....
its also free ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I use this, good program. I asked a similar question the other day, do a seach under my name and you will find it.Originally Posted by BJ_M
I would stronlgy suggest a VPN setup to do this and not remote control. Although it can be done via R/C -- it is certainly not very secure.
Well what they want to do is be able to access the server computer from any of their computers at home or other work sites whenever needed. They want to be able to do it even when someone isnt there. So I guess I thought PcAnywhere would be a good solution, but alot of you say it isn't very safe.
I am not familiar with VPN. What is this all about? Is it secure? Thanks for anything you can give me.
HatzLoves the funeral of hearts.....
Revolution in computing - The New HP Touchsmart
By cplevel42 in forum Newbie / General discussionsReplies: 15Last Post: 10th Sep 2011, 02:50 -
Eye Opener: Cloud Computing Power Requirements
By ahhaa in forum ComputerReplies: 3Last Post: 31st Mar 2010, 07:16 -
Which remote?
By Alomonger Pete in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jan 2009, 08:13 -
Remote
By WildParadise in forum Media Center PC / MediaCentersReplies: 14Last Post: 24th Apr 2008, 10:10 -
remote
By rtrg in forum Newbie / General discussionsReplies: 1Last Post: 1st Apr 2008, 13:46
