I use VobEdit to demux VOB file to .M2V and .AC3 files.
My question is: is there a way to tell VobEdit to demux a set of VOB files (that are in a single folder) automatically without having to demux one by one.
Any help is greatly appreciated.
Results 1 to 9 of 9
ktnwin - PATIENCE
In the demux box there's a check box to demux the complete title set(all vob's in a vts)just check it.
I have tried to check this box then click OK - nothing happens.
Can you tell me the exact sequence:
1) Open the .IFO file ?? and not the single VOB file ???
2) then select demux all (video / audio)
Is this correct ?
I will play with this tonight and see if it helps.
It a real pain having to go thru 20 VOBs files to demux themktnwin - PATIENCE -
I've got the same issue. I want to demux the vobs, but keep the demuxed chapters as seperate files. Everything I've tried, including VobEdit will demux the chapters into a single audio/video file.
Desperately need a batch demuxer as I've got I've got to demux over 250 home videos VOBs recorded on a stand-alone panasonic dvd recorder (because of non-compliant audio, reauthoring with just the vobs loses sound). -
Finally found a solution...
Using the /demux command line within DVDDECRYPTER, you can batch demux VOBS.
The target on the shortcut should look like this...
"C:\Program Files\DVD Decrypter\DVDDecrypter.exe" /demux 0x80 0xe0 /files VTS*.VOB
of course this works directly from the DVD vobs, not from folder / files.
see the readme.txt file for more command line options.
Hope this helps -
Originally Posted by ktnwin
Open VobEdit. Click the Open button and open the first vob in the titleset (VTS_nn_1.VOB. Click the demux button. In the Demux frame (the top one) tick the box that says "Demux complete title set". In the "Demux mulitple streams at once" frame (the bottom one) tick both "Demux all video streams" and "Demux all audio streams". This will iterate through all VOB files in the nn titleset.
Originally Posted by stilinsmIf in doubt, Google it. -
I don't see how the batch demuxing overcomes your problem of splitting at chapter points unless you start with each chapter in its own VOB.
Hi stilinsm,
thanks for figuring out the command line to demux a set to VOB files. This makes life easy.ktnwin - PATIENCE
Demux and Mux question
By danielmak in forum MacReplies: 1Last Post: 14th Feb 2010, 09:56 -
demux/mux question about avi to mpg conversion
By ibzomie in forum Newbie / General discussionsReplies: 4Last Post: 4th Jan 2009, 13:53 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19 -
Video 2X the length of audio after demux
By pchan in forum EditingReplies: 6Last Post: 18th Sep 2007, 22:51 -
TDA won't display video thumbnails after Vobedit
By spiritgumm in forum Authoring (DVD)Replies: 4Last Post: 25th Aug 2007, 14:35
