Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Jul 2001
    IL USA
    I have a svcd that I need to convert to a vcd. can anyone help me.
    Thank
  2. I suppose you would just encode them with TMPGEnc. copy the .DATs, plug 'em in, shoot out the new .mpg, just like anything else. A more detailed guide to converting TO VCD (mpg1) can be found in the "How To:" section to the left.
    Dec 2000
    Some airport, somewhere..
    No, there are no .dats in SVCD's. There is an utility that will allow TMPG to accept MPG2 files but I don't know if it works.
    I run DVD2AVI. Load it in and save a "project". That'll be a .d2v file (similar to a .avs file from avisynth). Just load in that .d2v file in TMPG and voila.
