OK, I have my edited home-video in .avi format
1: Use TMPGENC to transform the .avi files to .m2v and .wav files
2: Use TMPGENC DVD AUTHOR to transform the .m2v and .wav in DVD files (VOB, DUP, etc.) in the directory VIDEO_TS
3: Burn with Nero 6 using dvd film format or TMPGENC DVD AUTHOR
does someone knows this? Is it a good process?
No problems if you have the space on the DVDR. WAV or PCM audio is perfectly acceptable, it just takes up a LOT of space. Roughly 1 GB on a 90 minute movie. The same AC3 can be 300 MB'ish. That's 700 MB less for video, or roughly 33% of you possible bitrate.
There's nothing 'wrong' with your method 8)
Standards for NTSC DVDPlayers are PCM and AC3 (but 97% support MP2). For PAL it's PCM and MP2, but 99% support AC3 Audio. Most players are exactly the same for NTSC/PAL, it's just an internal setting. Why manufacture 2 players when 1 will do?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
If I have a good AVI, your procedure is correct!
However, I will convert the huge wasteful .wav to .ac3
It opens up more space to get a little less video compression. -
Do you mean space on hard disk? The final product, the DVD, is the same, even we use your method, Isnīt it?
Not sure who you are talking to...
But supposed you make a DVD from M2V and WAV and the size comes out to 5.1 GB when you encode it to VOB for DVD.
Well.. Convert that huge WAV to AC3 (224 bitrate) then encode back to VOB for DVD and voila it now is 4.2 GB and will easily fit on your DVD-R and you're VIDEO quality stays the same and your WAV is now Dolby Digital... High Tech!! Whee!!!!!!!!!!!
Recomended Software for fast simple compatible capture and conversion
By The Turtle in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2010, 15:10 -
.MTS to .avi conversion (video seems fast)
By puncho in forum Video ConversionReplies: 9Last Post: 12th Sep 2008, 01:49 -
Fast simple way to resize Xvid
By Maxwellbest in forum Video ConversionReplies: 8Last Post: 2nd Feb 2008, 17:32 -
Video conversion of .rm to .avi or .mpeg with fast forward and rewind
By skv19 in forum Video ConversionReplies: 3Last Post: 23rd Jul 2007, 21:48
