i seem to be having bad internet connctions latel. i have blueyonder broadband and dont know the problem. a temporary solution i found is turn off the power to my set top box and then switch it back on. this works but it keeps happening alot and is annoying when im downloading things. someone help please.
I used to have the same problem with my own router. It is a U.S. Robotics 8000A. The problem was related to a buggy firmware.
Look in the web page of your router for a new firmware. This may fix your probelm. -
That or call the cable company and tell your connection is "jacked up" they'll give you a new modem most likely or a new NIC card
Originally Posted by 808smokey
Do they give free support? And, is it their cable modem or your own?
The next time you're dropped, try Start>Run>winipcfg. Click on more info or details, or whatever your sys has, on the dropdown where it lists ppp....,highlight your NIC and see what the DNS Server address is. Try opening an MSDOS window and type "ping 000.000.000.000", your numbers, and a space after ping. Hit enter and see if you get a reply. It should ping 4 times, you should send and receive 4 packets. You might need www. after the ping-space, I forget.
I had to do this once when mine was new, and the tech said it proved my connection was good and I had other problems. I did, haven't had any since.
It could be a bad modem or NIC, though, as said above. Just that if you have to miss work for a service call, and this would show another problem instead, is worth a try, just for elimination.
Cheers'
George
WDTV Live needs to be physically disconnected when it couldn't play a file
By tigerb in forum Newbie / General discussionsReplies: 15Last Post: 29th Sep 2013, 13:50 -
Security risks for wireless broadband?
By yogart in forum ComputerReplies: 10Last Post: 16th Feb 2010, 12:49 -
Changing Broadband From AOL To Sky Help
By Nitro89 in forum Off topicReplies: 0Last Post: 12th Dec 2008, 14:36 -
Mobile broadband USA
By rhegedus in forum ComputerReplies: 14Last Post: 1st Nov 2008, 11:26 -
Kaspersky Internet Security 7.0 installation Conflicting with Internet Exp
By Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 03:36
