i have a number of svcd and vcd in cue & bin format on my harddrive which i had to copy paste from my old dying harddrive,i know some of them are now corupt but how can i find out which without playing them all and having to watch them all the way through.
is there a program that will check the bin file for bad frames so i know which to delete and which to keep?
Results 1 to 9 of 9
Burn to cdrw you cant go wrong.. lend them to your friends to watch
. Also this is what the fast forward button is for. Just shows how unreliable HD can be.. what make?? IBM I bet!
VCDGear witll strip out the MPG's from BIN/CUE's. It will also 'fix' the MPEG if you tell it to. You can then re-burn via NERO as VCD or SVCD(whichever is appropriate).
Copy/Paste shouldn't induce errors. That's a sign of a major failure if it happened.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
You could stirp out the mpg with isobuster, with skip errors on.
Originally Posted by Gazorgan
the harddrive was barely accessable and i was lucky to get what i did off it,i also lost a whole folder of avis which was about 50gb
thats maxtors for ya
thanks for your help guys i'll give 'em a go -
just another quick question,when these programs fix the errors do they delete the bad sections of film leaving gaps throughout the film?
I had a bad file once. Isobuster extracted the file and reported it had 18,000 file errors, I could not notice any problems at all. I am not exactly what it does to the errored frames.
It depends on the GOP structure. You can't just delete a frame anywhere you want. I have seen fixes that repeat the prior frame, producing the ghosting affect. Put it never last more than 2/3 of second (max GOP length). Small price to pay for a dead harddrive.
Have you tried any Harddrive recovery tools, like Emergency Recovery, or anything from the Maxtor site?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
i've given up on the drive now as its not even detected by my system now but i did manage to retrive 70% of the data before it died,i've got the reciept so its off back to maxtor soon as i get an RMA number for it
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 08:35 -
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 19:23 -
How to playback BluRay plz ?
By Cov(enant) in forum Blu-ray RippingReplies: 2Last Post: 16th Sep 2008, 17:44 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 10:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 17:52
