My Cyberhome dvd player will play mpg's straight off the disk which is nicethe problem is it wont see multiple mpg's, just the first one. is there something i can do to make it see the other mpg's or will i have to author the disk in some way?
Growing old is mandatory......growing up is optional ;0)
I am not sure of a solution to the player as I have never used one of these. You could join all the mpegs together though in tmpgenc with the merge and cut tool.
I could do that mate but i want to fill the disk with multiple films. if i joined them i would have to fast forward to the next film which is a pain
if i put a disc with mp3's in the player it see's them no problem so why wont it do that with mpg's? what can i do so it see's all mpg's and not just the first one on the disk?
P.S the cyberhome is an under tv dvd player just incase people think it's pc playerGrowing old is mandatory......growing up is optional ;0) -
Some players don't do ISO mode very well. It's funny, they will do MP3's but not MPEG's.
Does it Autoplay or do you get a menu? Try hitting menu and see if you get a list of MPEG's. Also try to avoid long names or complex symbols. Some players default to 8.3 naming convention.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
When i put the disk into the player it goes straight to the menu but only ever shows the first mpg. Also have used short names (eg - tls1 and tls2) so i'm stumped as to why it wont show all mpg's. At first i thought it might be something to do with not closing the disk but have done that and still no joy. I could just author the disk and make chapters but that takes time and i really want to get to the bottom of this little puzzle, weather it's something i'm not doing with the disk or limitations of the player itself.
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 13:01 -
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 18:52 -
My MENU wont autoplay on DVD player
By GREENDIVERS in forum Newbie / General discussionsReplies: 0Last Post: 9th Jul 2008, 11:39 -
WinDVD7 wont play PAL dvd with mpeg audio correctly ?
By deejay.2001 in forum Software PlayingReplies: 2Last Post: 26th Apr 2008, 14:57 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 02:43
