when i try to get 2 different sit-com clips onto a disk it says that they have to be the same aspect ratio.how do i get round this?.thanks in advance..using shrink,decrypter.pinnacle,nero,tmpgenc.
try this (i am just guessing as i dont use tmpgenc dvd author)
create first project in 4:3
start a new session and create second project in 16:9 in a new directory ..
rename 16:9 vobs as a continuation of 4:3 vobs
start a new session and import all vobs from session 1 and 2 (remember to rename first) ... and create dvd"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Just click Add new track in tmpgenc dvd author and you can mix different aspect ratios.
You can not mix different aspect ratios under same track/title.
How to Install Windows 7 O.S on new Internal Hard disk & make Partition ?
By skorpinok in forum ComputerReplies: 10Last Post: 26th Aug 2011, 07:13 -
Software raid over IDE & SATA disk
By RabidDog in forum ComputerReplies: 5Last Post: 11th Jun 2010, 23:58 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 22:32 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 06:55
........lee
