Dear Experts!
I know this problem was already discussed here but not yet solved, imho.
So, can anybody help to determine the things which cause nd1300 fail to read some media :
- PHILIPS 1-4x +R, just burned successfully at 2.4x on the same (!) drive,
- VERBATIM 1x -RW, erased on Toshiba sd5002.
In both cases, drive just spins the disc on and on, and any attempt to access it through explorer or other program hangs until the disc is ejected.
Philips +R disc can be well played by my standalone, though.
My system configuration is as follows:
- Athlon XP 1800+, VIA KT333 chipset
- NEC is on secondary master, no other dev on secondary
- Windows XP Pro SP1
- Nero 6.3.0.2
Thank you so much in advance for your answers.
I got the same DVD writer, try upgrading your firmware.
http://forum.rpc1.org/dl_firmware.php?download_id=1517
http://www.necd.de/software/1453_Firmware_ND-1300A_WIN10A.zip
I always use DVD-R. -
Well, thank you!
I forgot to mention : I am already on f/w 1.0A latest official.
Indeed, it seems -R causes less reading problems, but anyway:
- Memorex 1x -R (CMC...) - can not recognize (standalone reads)
- No-name 4x -R (AN31...) - the same.
Btw, I tried 1.07, 1.08, 1.09, and 108v2 unofficial - no change.
So, I conclude the problem is not in firmware - or, well, all NEC firmwares have the same bug
Hi there, "experts".
I have replaced my drive in the shop - the new one works perfectly.
The old one was manufactured in August 2003, the new one - in November 2003. Perhaps they had other bad drives in that August batch...
Good luck.
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15 -
MyFilms - A Software I Wrote
By qknet in forum SubtitleReplies: 0Last Post: 28th Sep 2007, 04:47 -
NEC ND-3520A writes DVD's, which it cannot read
By Ruut in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2007, 13:36 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
