hi i just tried my 1st dvd burn with nero and got an error
write error burn process failed at 2x
as far as i can get is the LEAD IN then i get heres the log
paul
1502-4240-1125-0482-1088-9784*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 29/01/2003 22:37:36
Nero Version: 5.5.10.54
Recorder: <LITE-ON DVDRW LDW-811S> Version: HS06 - HA 1 TA 0 - 5.5.10.54
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <LITE-ON DVDRW LDW-811S> Version: HS06 - HA 1 TA 0 - 5.5.10.54
=== Scsi-Device-Map ===
DiskPeripheral : ST340810A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW LDW-811S atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON LTR-24102B atapi Port 1 ID 1 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d343port Port 2 ID 0 DMA: ?
CdRomPeripheral : Generic DVD-ROM 1.0 d343port Port 2 ID 1 DMA: ?
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 347MB (355628kB)
Memory in use : 32 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Enabled (1)
Wizard: Off
23.1.2004
UDF/ISO compilation
09:58:48 #1 Text 0 File Isodoc.cpp, Line 7604
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
09:58:48 #2 Phase 111 File dlgbrnst.cpp, Line 1655
DVD-Video files sorted
09:58:48 #3 Text 0 File Reader.cpp, Line 115
Reader running
09:58:48 #4 Text 0 File Writer.cpp, Line 125
Writer LITE-ON DVDRW LDW-811S running
09:58:48 #5 ISO9660GEN -11 File geniso.cpp, Line 4571
First writeable address = 0 (0x00000000)
09:58:48 #6 ISO9660GEN -11 File geniso.cpp, Line 4571
09:58:48 #7 Text 0 File Burncd.cpp, Line 3769
Turn on Disc-At-Once, using DVD media
09:58:48 #8 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (original item values)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2274832 (2274832) = #2274832/505:31.7
relocatable, CD pos for caching/writing not required/required, no patch infos
09:58:49 #9 Text 0 File DlgWaitCD.cpp, Line 229
Last possible write address on media: 2297887 (510:38.37)
Last address to be written: 2274831 (505:31.06)
09:58:49 #10 Text 0 File DlgWaitCD.cpp, Line 234
Write in overburning mode: FALSE
09:58:49 #11 Text 0 File DlgWaitCD.cpp, Line 1703
Recorder: LITE-ON DVDRW LDW-811S, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
09:58:49 #12 Text 0 File ThreadedTransferInterface.cpp, Line 824
Prepare recorder LITE-ON DVDRW LDW-811S for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 364195840
09:58:49 #13 Text 0 File ThreadedTransferInterface.cpp, Line 672
Setup items (after recorder preparation)
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2274832 blocks [LITE-ON DVDRW LDW-811S ]
09:58:49 #14 Phase 24 File dlgbrnst.cpp, Line 1655
Caching of files started
09:58:50 #15 Phase 25 File dlgbrnst.cpp, Line 1655
Caching of files completed
09:58:50 #16 Phase 36 File dlgbrnst.cpp, Line 1655
Burn process started at 4x (5,520 KB/s)
09:58:50 #17 Text 0 File ThreadedTransferInterface.cpp, Line 1978
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
09:58:50 #18 Text 0 File DVDR.cpp, Line 1322
Recording mode: Sequential Recording Mode
09:58:50 #19 Text 0 File Mmc.cpp, Line 19092
Set BUFE: supported -> ON , Generic write control : ON
09:58:50 #20 Text 0 File DVDR.cpp, Line 1436
Start write address at LBA 0
DVD high compatibility mode: Yes
09:58:50 #21 Text 0 File Cdrdrv.cpp, Line 7931
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
09:58:58 #22 Text 0 File Writer.cpp, Line 316
09:58:58.440 - LITE-ON DVDRW LDW-811S : Queue again later (Intervall : 11msec)
10:01:14 #23 SCSI -1135 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02130000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
10:01:14 #24 DVDR -1135 File Writer.cpp, Line 333
Write error
10:01:14 #25 Text 0 File ThreadedTransfer.cpp, Line 222
all writers idle, stopping conversion
10:01:14 #26 Text 0 File ThreadedTransfer.cpp, Line 216
conversion idle, stopping reader
10:01:47 #27 Phase 38 File dlgbrnst.cpp, Line 1655
Burn process failed at 4x (5,520 KB/s)
10:01:47 #28 Text 0 File Scsicmd.cpp, Line 406
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 10:02:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29/08/2002 08:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) -
ok just upgraded to nero 6 and get a (power calaboration error) heres the log
paul
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 19:18:06
Nero version: 6.3.0.2
Recorder: <LITE-ON DVDRW LDW-811S> Version: HS06 - HA 1 TA 0 - 6.3.0.2
CD-ROM: <Generic DVD-ROM >Version: 1.0 - HA 2 TA 0 - 6.3.0.2
Adapter driver: <d343port> HA 2
CdRomPeripheral : Generic DVD-ROM 1.0 d343port Port 2 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d343port Port 2 ID 1 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LDW-811S D: CDRom0
LITE-ON LTR-24102B E: CDRom1
Generic DVD-ROM F: CDRom2
Generic DVD-ROM G: CDRom3
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Free physical memory: 350MB (358920kB)
Memory in use : 31 %
Use Inquiry : 1
Check supported media : Disabled (0)
23.1.2004
UDF/ISO compilation
11:01:08 #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
11:01:08 #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
11:01:08 #3 Text 0 File Isodoc.cpp, Line 6029
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
11:01:08 #4 Phase 111 File dlgbrnst.cpp, Line 1800
11:01:08 #5 Text 0 File Reader.cpp, Line 118
Reader running
11:01:08 #6 Text 0 File Writer.cpp, Line 124
11:01:08 #7 ISO9660GEN -11 File geniso.cpp, Line 3882
11:01:08 #8 ISO9660GEN -11 File geniso.cpp, Line 3882
11:01:08 #9 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
11:01:08 #10 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 2274831 (505:31.06, 4443MB)
11:01:08 #11 Text 0 File DlgWaitCD.cpp, Line 245
11:01:08 #12 Text 0 File DlgWaitCD.cpp, Line 2085
11:01:08 #13 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
11:01:08 #14 Text 0 File ThreadedTransferInterface.cpp, Line 779
original disc pos #0 + 2274832 (2274832) = #2274832/505:31.7
relocatable, disc pos for caching/writing not required/required, no patch infos
11:01:08 #15 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [LITE-ON DVDRW LDW-811S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4658855936, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2274832 | lead-out | 1 | 0x00 | 0x41
11:01:08 #16 Phase 24 File dlgbrnst.cpp, Line 1800
11:01:08 #17 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
11:01:08 #18 Phase 25 File dlgbrnst.cpp, Line 1800
11:01:08 #19 Phase 36 File dlgbrnst.cpp, Line 1800
11:01:09 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
11:01:09 #21 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 14:06,201 (846201ms) -> OK
11:01:09 #22 Text 0 File DVDR.cpp, Line 1512
11:01:09 #23 Text 0 File Mmc.cpp, Line 19451
Set BUFE: supported -> ON , SMART-BURN : ON
11:01:09 #24 Text 0 File DVDR.cpp, Line 1643
11:01:09 #25 Text 0 File Cdrdrv.cpp, Line 7941
Media Specific:
11:01:24 #26 SCSI -1106 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03510000
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
11:01:24 #27 CDR -1106 File Writer.cpp, Line 301
Power calibration error
11:01:24 #28 Text 0 File ThreadedTransfer.cpp, Line 229
11:01:24 #29 Text 0 File ThreadedTransfer.cpp, Line 223
11:01:24 #30 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was -1
11:01:24 #31 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
11:01:24 #32 Text 0 File dlgbrnst.cpp, Line 1658
11:01:24 #33 Phase 38 File dlgbrnst.cpp, Line 1800
Existing drivers:
File 'Drivers\d343port.sys': Ver=3.43.0.0 built by: WinDDK, size=5632 bytes, created 15/12/2003 17:29:42 (Adapter driver for src)
Registry Keys:
[/img][/code]
DVD error while burning in NERO 7
By coinsdrop in forum Newbie / General discussionsReplies: 19Last Post: 22nd Apr 2009, 11:46 -
Error Nero AAC - no HC
By albo23 in forum Video ConversionReplies: 1Last Post: 17th Aug 2008, 15:06 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 16:22 -
I keep getting an Error while transcoding with Nero Vision 3
By kiaconcepts in forum Video ConversionReplies: 4Last Post: 5th Jun 2007, 08:35
