  1. hi,
    i have a few movies that i want to encode and burn on disc. First couple wnt fine. But i have a couple that always produce the "cannot open file or unsupported" error message.
    Used avicodec to ensure that i had the right codecs and it informed me that it was indeed supported.
    Have tried to change the directshowfilter priority as per your problem page but it wont let do anything.
    Any ideas chaps?
    Feb 2003
    Copenhagen
    It can be a lot of things, try use fx VirtualDub to extract the audio as wav, then frameserve, and use that as input for tmpgenc.
    It is described in several guides on this page.
    Chr
    Where is the Deadly Viper Assasination Squad, when you need it ?
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi cooldog,
    With which tool do you get the error? It sounds like a fairly common TMPGEnc error, so I'll point you at this:
    https://www.videohelp.com/tmpgenc.htm#problems
    Hope that helps. Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. I agree with Chr0 if tmpgenc will not open it and vdub will, try frameserving to tmpgenc.
    If it's wet, drink it
    My DVD Collection
  5. hi guys,
    virtialdub says "no video frames found in mpeg file" when i try to open video file
    tried higher priority settings for directshow filters on vfapi plugins page.. no better
    avicodec shows this-
    File : 1.55 GB (1.81 GB), duration: 1:34:13, type: MPG, 1 audio stream(s), quality: 80 %
    Video : 1.66 GB, 2500 Kbps, 25.0 fps, 480*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
    Audio : 150 MB, 224 Kbps, 44100 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    any more ideas?
  6. helllllooooo....!
    any more ideas, answers, things for me to try?
    Steve
    Feb 2003
    Copenhagen
    Are you using the VirtualDub version that supports Mpeg2?
    If you do, the video stream may be corrupt.
    Chr
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Neither VirtualDub nor TMPGEnc can read MPEG2. But there is a version of VirtualDub that's modified to do so, and there is a plugin for TMPGEnc that allows it to read MPEG2. If PowerDVD is installed, TMPGEnc can (at least could) use its mpeg2 decoder to open mpeg2 (no need for plugin).
    /Mats
