I have a set of video files I wanted to put onto DVD.
File setups are as follows.
Video: MPEG1 352x240 (29.97), 575kbps (constant)
Audio: MPEG Layer II 48khz, stereo, 224kbps
Everything compiles without a hiccup. I, not wishing to waste a DVD-R, make an image file (using Nero 6 ISO/UDF setup) and then try to test it.
I get picture fine, but no audio whatsoever.
As a seperate test, I make the DVD as-is and test it with my set-top box. Same symptom: No audio, but video works.
Something else: when I use TMPGEnc (DVD author 1.5) to open up the created DVD file(s), I can then use the preview function and get sound out of it.
For the software DVD playback, I'm using "MSIDVD" (a version of WinDVD, IIRC) run though both Jetaudio Basic and Windows Media Player.
DVD set-top is a Toshiba SD-1600.
Did a Linear PCM conversion of the audio. Still no luck.
However, PowerDVD plays both just fine... weird. Sigh... Maybe it'll work on someone else's DVD player.
"Risk... is our business."
Extract the audio to a .wav file with VirtualDub or something similar prior to encoding. Seems as tho' TMPGEnc has lotsa problems with audio. Here's a tutorial:
https://www.videohelp.com/virtualdubaudio.htm -
I've got the problems somewhat nailed down: the other DVDs I've made (on another program, DVD Architect) used AC3 for the sound.
I have a feeling that the SD 1600 won't read MPEG II audio OR PCM."Risk... is our business." -
Originally Posted by LoH"Art is making something out of nothing and selling it." - Frank Zappa
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
Problems about aac audio in TS files
By ihmcjacky in forum Video ConversionReplies: 4Last Post: 30th Nov 2010, 01:24 -
MPEG1/2 related audio problems
By Kevlin in forum MacReplies: 3Last Post: 26th Aug 2009, 05:16 -
WD TV, Audio problems on 1080 mkv files.
By gustav32 in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th May 2009, 13:28 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 14:37
