Recently I decided to give it a try with the DVD shrink, mostly for being it freeware and getting extremely good notes; before that, I used mostly Smartripper or DVDDecrypter to rip my movies and DVD2One for shrinking it, but I missed some more control over what I will keep on a DVD and what will I dismiss. Everything worked well, I both ripped and backed-up two of my DVD's and kept the extra content I wanted to, burned them with NeroExpress as usual. Both of the back-ups worked well on my stand alone home DVD player, but every time I tried to play the on my PC I got the same error message
Error Code: 89020003
The DVD disc might have been damaged so as to inhibit playback operation.
The DVD disk is NOT damaged, and as far as I can recall, I set up a "region free" option while in process of ripping/encoding. I use Cyberlink's Power DVD 4.O XP as my PC DVD player.
What am I missing? Any help would be highly appreciated!![]()
Well, just in case that someone runs into the same issue, I will report my own findings.
Patched the Power DVD 4.0 with the latest available patch, it didn't help a bit. The DVD's I backed up with DVD2One replay without any problem on Power DVD 4.0, but those created with DVDshrink display the error message as reported above. I used Power DVD 4.0 for almost a year now and I was quite pleased with it, but after this happened, I took refuge and dug out the WinDVD 4 that I got with my laptop, but never have installed. I tried the DVDShrink DVD's with WindDVD and it worked flawlessly.
So, the issue is in Power DVD, which I have now dumped in favor of WinDVD; I like DVDShrink too much to give up on it, so WinDVD wins for a nose length.
DVD Shrink Problem?
By LCE in forum Newbie / General discussionsReplies: 9Last Post: 15th Jan 2010, 07:38 -
Problem using DVD shrink 3.2
By aldago in forum Newbie / General discussionsReplies: 12Last Post: 13th Feb 2009, 20:28 -
DVD shrink using 100% of cpu power, how is that possible?
By aslan in forum ComputerReplies: 10Last Post: 24th Sep 2008, 09:51 -
Dvd Shrink Problem
By letty in forum DVD RippingReplies: 5Last Post: 23rd May 2008, 08:09 -
Power DVD Copy Problem
By Tel in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 16:51
