I'm trying to convert my avi file (which I downloaded from WinMX) to a mpg file so that I can make it a VCD. I have TMPGEnc, I also downloaded the plugin (VFAPI). I tried opening the avi file for the video source, it says that it cannot be opened or unsupported. I opened it for the audio source, it loads great. Then I loaded the VideoCD (NTSC)template. It works. Then I went back to the Guide and told me to go here: http://www.vcdhelp.com/tmpgenc.htm#problems it told me to increase the AVI VFW to 1. So I did. I also copied the rest of the settings that was shown on the picture, which was to set all the rest to 0. Is that something wrong I did? Or is leaving it all 0 a good thing?
That's all the info you need I hope, or you can just ask me for more info in this topic. Thanks for reading this!
Just to make certain: You mention that you downloaded the VFAPI Plugin. But did you a) install it in the same directory as the program and b) execute the *.bat file which actually then installs the plugin?
<font size=-1>[ This Message was edited by: aldus4 on 2001-07-11 06:39:39 ]</font> -
i had da same problem, da avi file i open wit tmpgend said it was unsupported, get tmpgenc version 12a, it worked 4 me wen i got dis.
I did do that when I first downloaded it. Actually, I didn't know it installed. But I guess it did. And it is in the same folder.
I think it is installed or I wouldn't even be able to access the plug-in in the "Environmental Settings...". Can you tell me what the settings should be for each name in the VFAPI tab?
i had the same problem and i found that under options in tmpgenc it didnt have "tmpgenc.vfp is registered to vfapi" checked. checking it fixed the problem for me. so it might help you too
AviSynth 2.5x and Convolution3D guide for AVI captures
By FulciLives in forum User guidesReplies: 136Last Post: 22nd Dec 2010, 00:47 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
best software and guide for WMV-to-AVI..?
By snadge in forum Video ConversionReplies: 2Last Post: 26th Jul 2009, 18:24 -
AVI.NET -- User Guide?
By hurricane1951 in forum Video ConversionReplies: 2Last Post: 13th Jun 2009, 21:33 -
DVD/MPG to DPG Guide (for Nintendo DS)
By Ecko_Blue in forum User guidesReplies: 7Last Post: 4th May 2009, 11:47
