okay , i have a movie that is divx with ac3 audio, i want to convert to mpeg2 for a dvd with the ac3 still being used, what is the best way to convert the audio??? When i go to convert in tmpeg it says the audio will be a wav file, not ac3??? any help is greatly appreciated
Basically you use the ac3 as is and use TMPGenc for the video only, here's a guide.
"Art is making something out of nothing and selling it." - Frank Zappa -
ok when i put the ac3 file in bslice to correc it, it dosent do anything but open up notepad !!! with some specs from a old moive i tried a long time ago
You could just try skip the beslice step. It usually works fine anyway.
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 04:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
