You don't use a codec with Firewire transfer because you are transferring not capturing. Using Firewire you are simply copying a data file (that just happens to contain video) from one storage medium to another.
...but only for analogue capture, not file transfer using Firewire.Originally Posted by Tommyknocker
I'll say it again. DV transfer using Firewire is NOT CAPTURING. It is a simple file transfer. What you get on your hard drive is absolutely, bit for bit, identical to what you had on your DV tape. There is no re-encoding. The only encoding that has taken place is when the video was encoded to DV in the camcorder so it can be stored on tape.
The only time anything would bugger about with your video is if you are using something which encodes to mpeg on-the-fly as you transfer. That is a sure fire way to end up with shite quality and a file that you can't sensibly edit. Simply transfer as avi. -
This is possibly the DV codec used for playback causing the apparent reduction in quality. Try installing either the Canopus playback only DV codec or the Panasonic DV codec. both can be found in the tools section and are considered by many to be superior to the standard MS codec.Originally Posted by schematic2
thanks for the reply bugster. I'll try that this weekend. I hope you are on to something here.
Capturing DV without Firewire
By indijay in forum Capturing and VCRReplies: 8Last Post: 4th Dec 2011, 10:41 -
doubts about capturing via firewire
By v1p0n3 in forum Capturing and VCRReplies: 2Last Post: 24th Aug 2010, 11:10 -
Help Capturing DV, no Firewire
By fozzieb in forum Capturing and VCRReplies: 5Last Post: 6th Jul 2010, 14:07 -
Capturing with firewire problem
By towarmforacoat in forum MacReplies: 5Last Post: 7th Nov 2009, 04:15 -
Capturing from STB with firewire.
By Red Hat in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 05:50
